Results 1 to 3 of 3
    Pakistan
    Default Skystar-2 Problem while changing the polarity
    Dear Saed and other Experts I have a problem while changing from Horizontal to Vertical channels and vice versa on Progdvb as well as AltDvb. Basically the signals from the satellite dish which has Ku as well as C-Band LNB installed with a Diseque Switch pass through a satellite receiver to the Skystar-2. Previously I could select Horizontal as well Vertical channels on Progdvb as well as AltDvb independently while the digital receiver was in standbye mode but it seems that after an upgrade of the software of the digital receiver i.e., Starbox ITS-5400 I am unable to change Horizontal and Vertical channels on Progdvb as well as AltDvb and there is no signal seen while the digital receiver is in standbye mode and the signal is received only when the digital receiver is on a particular polarity and completely switched on. Please guide me how can I get both polarities working on skystar-2 for better searching. Do I have to alter the settings of antenna settings of my digital receiver which has Normal, Disec 1.2 and Usals support in software.
    May 2004
    Default Re: Skystar-2 Problem while changing the polarity
    Quote Originally Posted by iqbalbhawana
    are you using Diseqc 1.2/motor in your receiver ? if everything was perfect before upgrading the latest firmware on your STB then try upgrading the newer one, wait if not yet arrive. i dont think there will be any problem in your settings in ProgDVB or Alt-dvb if both were woking fine.
    Pakistan
    I have a motorized dish but it is not operated through digital receiver or disec switch. It is operated independently. There may be something wrong with the new software installed in the receiver or maybe I have unintentionally deleted some necessary skystar-2 files as I ran HIJACKTHIS scanning software over my computer system.
    Anyway Thanks,
    Iqbal Bhawana
  1. skystar 2 problem
    By deutsch in forum RDI - English
    Last Post: 18th October 2006, 02:44
  2. Queery: Polarity R/L
    By scorpionz in forum RDI - English
    Last Post: 25th July 2006, 10:58
  3. View Polarity R & L frequancies from yamal
    By dodo1 in forum RDI - English
    Last Post: 22nd October 2005, 17:14
  4. Replies: 4
    Last Post: 20th June 2005, 08:09
  5. help for polarityL and R POLARITY
    By Fattah in forum RDI - English
    Last Post: 16th May 2005, 01:10
