    Default plz help me in dis
    HI i have skystar 2 tv DVB card and i m using progDVB when i open any channel it generat a error
    " Error! Filter Not Founded " Elecard_MPEG2_video_cecoder"
    and i just hear voice but video is not coming
    what can i do now plz tell me i m waiting
    Help Me
    May 2004
    Re-install ProgDVB and during installation dont forget to click on "Install Elecard MPEG-2 decoder for soft mode"
    and then if still error then install Cyberlink PowerDVD or InterVideo WinDVD software or install Elecard MPEG-2 decoder.
    easiest solution : reinstall progDVB and check "register elecard filters.." when asked for
    w/o reinstall solution :
    --> go to windows/system32/
    --> find regsvr32.exe and copy it to filter folder of ProgDVB
    --> drop all *.ax files that you'll find there on the regsvr32.exe file
    --> you should get some messages like this "xxxx.ax have been sucessfully registred.."
    --> that's all!
    Default thx all
    but is there any xxx channel on eutelsat w3
    and how can i see locked channels
    plz help me in dis metter
    Help Me
    Default thx all
    well is there any xxx channel on eutelsat w3
    and how i can see them
    and tell me how i can see locked chaneels is leye any solution
    Help Me
    by xxx i don't mean a channel but a file name
    i think u should better reinstall progdvb as shown in the second post
    i mean that is there any sexy ( blue) channel on Eutelsat like XXL.
    and how i can see locked channels and tell me about recording if i want to record movie then what soft i can use for better result
    Help Me
