Results 1 to 10 of 10
    South India
    Default MINIMUM DISH SIZE REQUIRED TO VIEW FTA FROM ASIASAT3S INDIA
    Hello friends.. please guide me .. what is the minimum dish size required to received FTA channels from Asiasat3s and other satellites such as Thaicom, in India.. I want to know the dish size required to view these channels in India.. Please post the required things such as the LNB type and dish type etc..
    Thanks.
    East Malaysia
    Default As 3c and Thaicom
    My Frd please check with LyngSat.com ( SatTracker) if the mentioned Sat signals falls in your area and check the Q level.if it is about 80% then you can use a 6ft dish with a C band LNB.
    I can Rx NSS 703 and Insat 2E from India with high Quality.
    95° East
    Default Re: As 3c and Thaicom
    Quote Originally Posted by Gregory Carmal
    Dear - what is this Q level?
    can you please advise
    Regards
    May 2005
    sharjah - uae
    Default what is "Q"
    I THINK HE MEAN FOR QUALITY.
    RGDS
    NOTHING IS IMPOSSIBLE
    95° East
    Default Re: what is "Q"
    Quote Originally Posted by sanil
    RGDS
    Dear,
    Even if Quality - which is not mentioned over there.(Lyngsat)
    Regards
    South India
    I want to know the minimum dish size required to view the channels from Asiasat 3s in INdia.. ..
    what is the dish size required in India to view channels from asiasat3s.. and what are the other technical requirements..
    Union territory
    Dear,
    u can watch asiasat 3/asiasat2/[email protected] etc.. in 4ft ku band dish with c-band lnb
    pl visit the link.
    http://www.apnadth.com/combo_DTH/combo_dth.html
    Quote Originally Posted by mj786
    Try this site
    http://www.satlex.de/en/azel_calc-params.html?
    open this site and put your location/wanted satellite
    if you not known your location
    try www.worldmap.com
    South India
    Try this site
    try www.worldmap.com[/quote]
    Dear bablu.. thanks for the links.. but those data is going on top from my head.. there is lot of things in that but I cant understand much about it.. ok anyway thanks.
    There is no clear thing which says the dish size or so.. ok maybe i am not able to understand it.. ANYWAY THANKS
    Try this site
    There is no clear thing which says the dish size or so.. ok maybe i am not able to understand it.. ANYWAY THANKS[/quote]
    you able to find your location
    click this site
    http://www.multimap.com/index/IN1.htm
    find your city and click on it
    now you see your location
    note it and then go
    http://www.satlex.de/en/azel_calc.html
    put your location /wanted satellite
    there is no dish size but you see many other intresting things
    in satlex menu you see many option and you able to find many things in eirp values you able to think about your dish size for c or ku band
  1. Dish Size Chart
    By Anver in forum RDI - English
    Last Post: 8th July 2006, 20:52
  2. DISH TV INDIA help required......
    By jigneshpatel in forum RDI - English
    Last Post: 6th July 2006, 03:27
  3. dish size
    By peterm165 in forum RDI - English
    Last Post: 23rd June 2006, 16:44
  4. dish size on turksat in kuwait?? help me out plz
    By nightrider083 in forum RDI - English
    Last Post: 5th January 2006, 23:38
  5. What will be the size required to get Telstar 18
    By tapta in forum RDI - English
    Last Post: 19th September 2005, 14:52
