    Lahore
    Default ToH3.4 HoT7.5 for Humax is out!
    click here to download latest s/w for HUMAX 5400/5400Z
    you may try on
    http://www.mach1.ws/showthread.php?t=19777
    Fte Max 100S
    Humax IRCI-5400z
    Nov 2005
    KSA
    whats new with this dot version now ?
    STB info:
    Humax5400 with ****** FREECAM 2-019, Coship, Manhattan Plaza ST550 PVR with 80GB Maxtor Quickview HDD.
    Dish Info:
    HotBird,NileSat;ArabSat;Panamsat-10,AsiaSat3s
    Subscriptions:
    Showtime,Pehla
    Lahore
    Humax ToH3.4 HoTplugged v7.5 - 2006-05-26
    -- Version: A --
    - CW RSA Fix
    - MTV Hits! ok
    - MTV Base ok
    - VH-1 Classic ok
    - Premiere World ok
    - D+ ok
    - included keybin
    - full suport for greece language
    Fte Max 100S
    Humax IRCI-5400z
    In a Weird RooM
    still no tps jiiiii...
    Lost Ice Cap of Kilimanjaro
    Default TPS on HoTv7.5
    Yes, it sure works but...
    1. you must use the latest DSR EMU 9500
    and
    2. the very latest key.bin or manual entry is required.
    The TPS and Multivision do indeed work.
    But please note that during "rush hour" time TPS may change coding as often as every 30 minutes or so
    If TPS doesn't work, you can always check the validity of your work on "Mezzo" (HB), coding of which seems to be changed less frequently.
    Taro
  1. New ToH3.4 HoT7.5
    By xawiq in forum SD Receivers
    Last Post: 29th May 2006, 22:50
  2. Replies: 0
    Last Post: 26th May 2006, 14:02
  3. ToH3.4 HoT7.3 is out!
    Last Post: 11th May 2006, 06:39
  4. ToH3.3 HoT7.2 for Humax is out!
    Last Post: 9th May 2006, 15:16
  5. ToH3.3 HoT7.1
    Last Post: 25th March 2006, 13:22
