Results 1 to 15 of 21
    In everybody's heart
    Default C band and KU transponders on a same dish
    Can I receive C band and KU band signals from the same dish
    I want to receive Insat 4a 83.0 both frequencies.
    canine consultant Expert
    There are some cheap combined Ku , C-band LNB's available, which are also reasonably priced.
    but, if you have a mesh dish, the dish may not suit Ku signals, you will need a dish with very,very fine mesh, or better still a solid dish.
    regards from OZ bassett
    SATELLITE GURU Expert
    Quote Originally Posted by bassett
    Yep get a dual KU C band LNB
    DISH CITY Teacher
    India
    Yes it is possible by choosing a C+Ku combo feed horn. Better use SOLID dish
    Megahertzpark
    Thanks for the info.
    Feb 2006
    Quote Originally Posted by irdeto2engineer
    Could you pls tell me which Brand this LNB. How much it cost.
    Having 3 IF-connectors how does it works. Does Diseqc switch is required to combined both C and Ku. And what is the specification for C and Ku
    Thanks...
    Nov 2005
    North Waziristan,MirAli,Pakistan
    WILL THE RESULT BE AS GOOD AS USING A SEPERATE KU/C,LNBs .OR THE SIGNAL WILL LOW USING THE ABOVE MENTIONED ONE.
    Abdur-Rehman Dawar.
    Hello guys,
    I have a similar problem,what is the brand name of the dual c/ku-lnbf?
    thxs
    baba242
    Hello Friends,
    I would like to know whether dual LNB (C + Ku) will work on one dish position. As I understand, C and Ku archs are at somewhat different positions (vertically up/down). Has anybody tuned this LNB in Islamabad, say for Thaicom, Asiasat3, etc.
    Please give some details, especailly Experts should give their opinion.
    Lahore
    Due to non availability in Lahore market ,,I couldn't check it
    Fte Max 100S
    Humax IRCI-5400z
    Sep 2004
    SunshineState,Australia
    It is sold here In Australia n NZ for about A$150 plus postage.
    Many satellites viewers, are trying to get one,
    To me it is too early to digest the new technology, but
    it looks good.
    Because as Bassett(above) said that it is only good for solid dish.
    (not the Mesh Dish.)
    Thanks for reading my mail.
    JPS-Australia
    Africa-Kenya-Nbi
    Quote Originally Posted by JPS
    it looks good.
    I was thinking of this dual lnb but the cost tells me to wait, and that slows down experiments. any cheaper option please?
    Dstv HD PVR
    Nov 2005
    I THINK ITS AN EASY SOLUTION FOR THOSE WHO ARE USING TWO LNBs IN A MOTERISED DISH.COZ ITS COMPARETIVELY DIFFICULT TO SET TWO LNBs(C&KU)IN ONE DISH.
    Abdur-Rehman Dawar.
    Indian Ocean
    It is possible. Here is my config: Yuri LNB Dual C and Ku Band with built-in Disecq switch which cost around 110 USD - 3,74m motorised mesh dish which I move with a Drake Esr700- Skystar2 2.6C with ProgDvb.
    And it works good both on Circular and Linear signal with a teflon dielectric (I reduced the thickness by 2)!
    I also removed the original plastic cap of the C-Band LNB and replaced it with a piece of plastic bag from my hypermarket: the signal quality is 10% higher.
    PIV 2.66Ghz RAM 512Mo WinXP Pro Sp1
    Skystar2 - 3.75m KTI- Drake ESR700e - Yuri 15 k C-Band - Sharp 0.6 dB Ku-Band
    Chennai, India
    Quote Originally Posted by salomon
    What do you mean by reducing the Teflon thickness by 2? Is it 2 cms or 2 inches? Where was the original LNB cap? Did you mean the cap wich would be in the feed horn or is it different? I would also like to improve my reception that's why I am asking.
  1. EIRP values and dish size for Ku-band
    By MariusT in forum RDI - English
    Last Post: 27th September 2006, 18:27
  2. Channels viewable with Ku band dish from Asiasat 3s
    By mj786 in forum RDI - English
    Last Post: 18th May 2006, 15:52
  3. ku band dish
    By prparab in forum RDI - English
    Last Post: 11th November 2005, 13:27
  4. Recieving NSS 6 with C band 2.3 dish
    By dodo1 in forum RDI - English
    Last Post: 6th July 2005, 14:35
  5. Replies: 4
    Last Post: 27th June 2005, 04:31
