Results 1 to 9 of 9
    LAHORE-PAKISTAN
    Default Need Urgent help from experts ------- which receiver to buy
    I have a world in box - ii + ci receiver and want to replace it with some other receivers please advise me the best available in lahore market. please also write the benefits/advantages of that receiver.
    thanks --- sethi
    sethi
    canine consultant Expert
    Whatever anyone tells you, is only there personnal opinion, and what might work for oner person , may not work for another.
    Your best bet, would be to contact friends with satellite set-up's and view what there using.. and be guided by that..
    regards from OZ bassett
    95° East
    Default Re: Need Urgent help from experts ------- which receiver to
    Quote Originally Posted by sethi_mg
    thanks --- sethi
    Dear
    In which way you are looking the receivers - Price wise or steability(support) wise?
    I suggest you for a better support(a much better) - HUMAX 5400 or your budget allows then buy a DREAMBOX
    Regards
    LAHORE-PAKISTAN
    Default receiver to buy
    i want to purchase a receiver with best back up soft ware my purchasing power is rs. 4000 - 5000 and if humax what about its price new and used and from i can get it.
    sethi
    Apr 2006
    Hotbird
    My personal favourite is the systar2 pci card (for computers)- it allows you to view pirated satellite tv on your computer. though for that I recommend at least a 17 inch screen.
    XSAT 410 / 430 because box key and ird are all known ($FF's)
    and they can be reflashed with maestroflash 418 to be ******, seca, nagra and allcam versions (latest Bolt N2)
    PC with 1020A Twinhan using Mytheatre, Fenrir, Snitch and Yankse
    95° East
    Dear
    You woun't get HUMAX fot that budjet, better contact Usman Lahore or Masood, they might be having a second-hand model of the same.
    If the budget is low - I also recommend to buy a DVB card - best SKYSTAR2
    Regards
    May 2004
    yeah i also recommend you pc dvb, skystar or twinhan which ever available. you can enjoy card sharing also in cheaper price.
    Lahore
    Go for "used" Super-CI 6000 Plus as this box is competing Humax now a days and Asifde is here for physical support
    Fte Max 100S
    Humax IRCI-5400z
  1. HELP OF EXPERTS NEEDED on receiver called RTG GADA
    By koolguyme in forum RDI - English
    Last Post: 4th September 2006, 21:56
  2. experts of technosat receiver
    By dodi in forum RDI - English
    Last Post: 7th August 2006, 17:13
  3. Urgent help (lovbird ) and experts
    By weso in forum RDI - English
    Last Post: 27th July 2006, 20:22
  4. Need Urgent Help for Humax VA-FOX Receiver
    By jafri in forum RDI - English
    Last Post: 15th August 2005, 11:27
  5. asifde urgent urgent
    By code64 in forum RDI - English
    Last Post: 14th July 2005, 23:28
