    Default Masod , saeed . bokony ph please need help
    Dear exprts, recently i changed my tv from normal TV (old) to a new HDTV wide screen TV , then after, all the chanels now recieved in a very bad quality colours ( as a bad cheap copy of video cd ) plus like a small small squares in the screen while all the that chanels is ok in old TV, so what you think the problem is from the dsr or the dish size or LNB or connections? in DVD itis playing very good and very clear. please help.
    PAKISTAN
    Default Re: Masod , saeed . bokony ph please need help
    Quote Originally Posted by weso
    maybe your STB problem..try to search your Tv Guide on internet and also read Manual book of your Tv.I think your Tv is working fine becoz DVD playback is clear.
    Check your Tv settings and Read Manual Book.
    For solution wait for Experts :P
    Good Luck
    Nov 2005
    Aslam O alaikum,
    Friend, are you using AUDIO VIDEO cable or RF cable?
    If your Tv is clear on local ANTENNA then your TV is O.K.
    It may be the fault of your cable ( STB to TV).
    Apr 2006
    HDTV means aspect ratio 16:9 .If broadcasters broadcast channels in HDTV mode only then you can get actual HDTV out put. Most of broadcasters are on normal aspect ratio 4:3.
    May 2004
    your tv is so high quality and your source is poor analog and non hdtv compliant so no wonder the picture quality is not good. Try your tv with HD movies
    Lahore
    Try to use a scart cable with DSR and TV
    Fte Max 100S
    Humax IRCI-5400z
    May 2004
    @weso
    no matter what cable or media you use, s-video, rca analog cable or scart etc you input is still analog and can never give the result of digital hd video quality. No wonder your all other high quality media giving you good quality on your tv.
    try playing hd movies of HDtv satellite feeds on your tv and you will experience the real output of your tv.
    Thank you friends thank you saed .
    Technosat, Humax, Starsat, Metabox, Kaon, Dreambox, Nokia, and echolink all i have in one room.
  1. need advice from bokony-ph and experts
    By weso in forum RDI - English
    Last Post: 2nd July 2006, 01:02
  2. Saeed bhai...plz help
    By superman001 in forum RDI - English
    Last Post: 30th December 2005, 15:21
