Results 1 to 2 of 2
    Middle East
    Default Need help for Echosat X-7
    I reset my receiver (Echosat X-7 CIM) to factory default and scanned the only satellite channels that I need, Hotbird. Unfortunately, I am no longer able to watch the encrypted channels that I normally do before I reset my receiver.
    Another question, can use the Super Echosat X-7 software patch on my receiver.
    Any advise will be highly appreciated.
    Strong 4620II
    jeddah
    Default echosat x7
    All you need to do is load only the hex file from funcard 6 in 1 by using Hyper Terminal as a loader.If you want to check the hex file from STB press Menu, Installation and input password 0937,if password doesn’t appear,you must check first parental control,menu lock must be ON.For the Super echosat I think it will not.
  1. Echosat
    By saad3000 in forum RDI - English
    Last Post: 4th June 2006, 00:54
  2. Zee tv and zee cinema+Echosat x7
    By Bazigar in forum RDI - English
    Last Post: 1st May 2006, 00:09
  3. Key Updatitng for Echosat X-7
    By jp4620ii in forum RDI - English
    Last Post: 19th February 2006, 10:38
  4. ECHOSAT USERS
    By gjawhar in forum RDI - English
    Last Post: 23rd January 2006, 12:29
  5. HELP.........Echosat
    By RAFI in forum RDI - English
    Last Post: 16th May 2005, 16:05
