Results 1 to 15 of 22
    Feb 2006
    Default sharing dish and single LNBs in 2 receivers???
    To all experts,
    I need help or information if it is possible to share dish and single LNBs in two receivers. Thanks m8
    Lahore Pakistan
    Dear
    Yes parchise new two output port LNB and you can link two receiver on one dish.
    Africa-Kenya-Nbi
    yes you can use 2 output lnb but only if it is ku band, also four is possible by using 4 output lnb - still on ku band only.
    Dstv HD PVR
    Apr 2005
    I'm sharing my C-Band lnb with four friends and Ku Band utilizing my self(single output)
    Lahore
    Quote Originally Posted by cogil
    I'm also sharing 2 C Band LNBs with one dish
    Fte Max 100S
    Humax IRCI-5400z
    Feb 2006
    Thanks for the informations guys, but im asking 1 output LNB(KU) to share in 2 receivers.
    Lahore
    Quote Originally Posted by otaner2k6
    You may do that with twin KU Band LNB not with one outlet or mono LNB
    Fte Max 100S
    Humax IRCI-5400z
    Africa-Kenya-Nbi
    Thanks for the informations guys, but im asking 1 output LNB(KU) to share in 2 receivers.[/quote]
    yes you can but from receiver one to rcvr 2, (not from lnb to rcr 1 and 2) powered by 1st receiver,
    and 2nd rcvr cannot switch polarities, it will depend on polarity switched by 1st rcvr.
    that is if 1st rcvr is on V then 2nd receiver can only do the v polarities without changing to H. if 1st rcvr is on H then both have to do H transponders only.
    try it out, give us answers
    Dstv HD PVR
    May 2005
    Persian Gulf
    Default 2-wat splitter
    Try using a-two way splitter, this provides 2-outputs connected to two receivers from one (Hotbird)satellite dish. I am presently using Eurostar EPD-12 plus/950-2150 MHz splitter, a cheaper one. A better quality splitter maybe the best option. This looks like a DiSEq splitter but in smaller size.
    Opportunity knocks only once!
    Aug 2004
    m8,
    yes its posible even for 5 stb.but you will need 2 lnb.!you will need to seperate Vertical from Horizontal Polarity.One Lnb will give the Vertical signal for vertical TP only and the other is for Horizontal viseversa.
    If it is only for personal usage,like the other m8 suggestion.i also suggest u to use lnb with 2 or four output defending on ur need.Now I'm using lnb with 4 output.Three of us with my friends are using Sat. card. The other output is for STB.All are working at one time without any problem.
    Feb 2006
    try it out, give us answers[/quote]
    Thanks m8, well said, but is there any adjustment on the system setup? i will try what you said, and i will let you know the result.
    Africa-Kenya-Nbi
    keep, second rcvr, LNB power off: there should be lnb power 14,18 and off,or V H and off, while the first rcvr lnb power is on to serve the lnb.
    on some rcvrs like one panasat you must enable output from the first rcvr to the next. so check your stb settings depending on the make
    Dstv HD PVR
    Feb 2006
    I tried last night and it works on same polarities(scanning and viewing channels) for a couple of mins then signal came out in both rcvrs (this is no adjustment on the 2nd rcvr). will try again. thanks m8, God Bless
    95° East
    Dear,
    I am using 4/1 Diseq - with 2 KU and 1 C but as I said earlier(on a different thread), C band signals are strange - If I scan with the orginal freqency nothing will appear - always to scan as reduce 600Khz from the original freqeuncy -example 3600 - reduce 600, scan as 3000 - then the signal will appear on C Band - what a strange.
    Now I added one DVB tuner but worrying the same thing will happen there also . I think I need to buy 4/2 Diseq for 2KUBand and 1 C Band
    Is there any recommended brand - please advise
    Here(where I live) all are duplicates SAT related products - made in assholes - I excuse for my language.
    Please advise.
    Regards
    Africa-Kenya-Nbi
    @anver
    i will try out your frequncy theory and also see what happens when i reduce the actual value.
    about the diseqs i dont have an idea which one to buy.
    Dstv HD PVR
  1. Multi Lnbs on one dish in Southern Africa
    By mafutah in forum RDI - English
    Last Post: 16th December 2006, 08:32
  2. MUTIPLE LNBS VIA DisQEC TO TWO RECEIVERS.
    By bubbles in forum RDI - English
    Last Post: 28th December 2005, 16:42
  3. Multi LNBs on a fixed dish
    Last Post: 17th November 2005, 04:59
  4. one dish antenna four receivers
    By rafay in forum RDI - English
    Last Post: 29th September 2005, 13:01
  5. Two SATs on one dish with two LNBs
    Last Post: 26th June 2005, 18:20
