    Apr 2004
    K.S.A
    Default twinhan DTV-STARBOX DVB CARD,HELP
    DEAR FRIEND'S YESTURDAY I BUY DVB CARD>TWINHAN DTV-STARBOX
    CARD.I CONNECTED DVB CARD IN MY PC.IT'S WORKING FINE I GOT ALL HOTBIRD CHANNEL'S!BUT ONLY FREE2AIR.I WANT GET PAY CHANNEL'S ALSOSO PLZ. TELL ME HOW2GET IT.NEED SOFTWARE TO OPEN ALL PAY CHANNEL.FROM WHERE I COULD GET PLZ.TELL ME PLZ.STEP BY STEP OK
    May 2004
    use the plugins (s2emu, yanksee, etc), if you are using the original software supplied with the card to view tv channels then you have to use ProgDVB, MyTheatre, ALT-DVB or any other suitable software.
    Apr 2004
    K.S.A
    thank's 4 reply saed but where is software?plz.give me a site 2 download it.
    Apr 2004
    Dubai / UAE
    Default progdvb
    Dear Ajnabi
    You can download the latest version of Progdvb from www.progdvb.com. The latest s2emu & the laest Softcam key is available at www.croteam-sat.com all the time.
    Install progdvb on your pc. while installing, select twinhan compatible hardware.
    then put the latest s2emu.dll and softcam files to C:\progdvb directory or to c:\progdvb\plugin directory.
    thats all..... all the scrambled channels available at the moment will be opened.
    regards
    May 2004
    all emus/plugins files can be downloaded from http://www.********.com/uploadshow.php?id=2
    and in ProgDVB put the plugins in C:\ProgDVB instead of ProgDVB/plugins folder if it doesnot work.
    wish you good luck
    95° East
    Dear Saed,
    Can you please advise on this card - as I am planning to buy a DVB card.
    PINNACLE DVB 400i - S
    ORBIT - VP1030
    is that good to have any of the above ? or any suggestions.
    Regards
    May 2004
    Quote Originally Posted by Anver
    Dear Saed,
    ORBIT - VP1030
    both cards are good but Pinnacle is less supported by third party softwares/plugins. Orbit VP-1030 is an OEM product of Twinhan VP-1030, you can buy it and it is widely supported.
    95° East
    Dear,
    Thanks for writing back, let me continue this in the PC-DVB section., please check over there.
    Regards
  1. TWINHAN VISIONPLUS 1030 PCI card
    By skycom in forum RDI - English
    Last Post: 14th August 2006, 18:48
  2. Att. Experts <{Twinhan card and Internet}>
    By SHY in forum RDI - English
    Last Post: 26th June 2006, 21:06
  3. Caderi de semnal pe card twinhan
    By nick61 in forum Placi DVB
    Last Post: 31st May 2006, 19:28
  4. Twinhan DVB-S Card Problems...
    By irvine in forum RDI - English
    Last Post: 12th October 2005, 10:26
  5. Twinhan Card
    By picieri in forum Placi DVB
    Last Post: 22nd March 2004, 04:15
