    Default Humax 5400 problem
    Hi all,after cleaning my hummy i download software 7.1 full and in the key section there is no any key inside,everything is 00000000 i try to put the key manually when finished i press ok to store but the key refuse to be stored and rechange to 00000000,several times i tried but fail,then i donwload the latest keybin using DSR 5.2 but still no key in the flash can somebody guide me pls
    ssss
    In a Weird RooM
    Default Re: Humax 5400 problem
    Quote Originally Posted by christo
    u should download the demo of humax from the rdi upload humax files..
    anyways u need to download the key through key editor or sammy hummy first download the key then verify it ... both are necessery ... first download the key.bin then verify the key...
    thanks a lot,any other method?
    ssss
    Aug 2004
    After keyupload or manually update: go into installation menu and exit, maybe this helps to store the keys.
    Lahore
    Keep your box in ON mode at FTA channel and in preselect i,e card+emu+s
    Fte Max 100S
    Humax IRCI-5400z
    Use Samy_Humy_Edit and it will work!
    thanks for all your guide,problem solved
    ssss
  1. humax 5400 problem
    By jim in forum RDI - English
    Last Post: 29th January 2006, 14:42
  2. humax 5400 problem
    Last Post: 20th January 2006, 15:31
  3. HUMAX 5400 PROBLEM
    Last Post: 6th January 2006, 03:32
  4. HUMAX 5400 PROBLEM
    By stefen in forum RDI - English
    Last Post: 17th November 2005, 00:44
  5. humax 5400 z problem
    By leventenagy in forum SD Receivers
    Last Post: 12th September 2005, 23:57
