Results 1 to 3 of 3
    Apr 2006
    Default altdvb diseq help
    salutare,
    tocmai am facut o achizitie, un nou lnb, acum am 3. am schimbat diseq switch-ul cu unul cu 4 intrari si o iesire. acum am setat eutelsat 7e, hotbird 13e si astra 19,2e. daca folosesc oricare doi sateliti (de ex eutelsat si astra), si setez la diseq lnb1 astra si lnb2 eutelsat, si pun simple diseq, merge ok. daca pun si al treilea lnb, in acest caz nb, atunci setez la diseq commited, astra lnb1, eutelsat lnb2 si hb lnb3. in acest caz nu mai vad nimic pe hb, si nu se comuta tot timpul de pe astra pe eutelsat cand schimb canalul. are careva vreo idee?
    altxro
    Pentru inceput pune "TX Counter" (in fereastra de editare sat) pe 2.
    Daca spui si ce placa DVB folosesti (si ce versiune de driver) poate imi mai vin si alte idei.
    Eu am acasa 19.2E+13E+MobileDish prin Diseq switch noname si merge binisor cu SkyStar1,SkyStar2 (drv. 4.3.0/Mibi) & Twinhan
    Apr 2006
    pai am urmatoarele:
    placa ss2 de la technisat, driver 4.40 luat de la technisat de pe site
    altdvb 2.1
    2 lnb-uri nu stiu ce firma si un strong
    am setat astra 19,2 hb 13 si eutelsat 7
    am un diseq 4 intrari o iesire
    am incercat setarile astea:
    diseq simple, lnb1 astra lnb2 eutelsat sau hb, merge ok
    diseq commited, lnb1,tx1 astra , diseq commited, lnb2, tx2 eutelsat, diseq commited, lnb3, tx3 hb.
    in cazul asta merge doar astra, pe hb nu am semnal deloc, iar pe eutelsat am semnal doar pe 1 sau 2 tp-uri
  1. switch diseq dupa switch diseq
    Last Post: 5th July 2006, 23:20
  2. About diseq
    By potencia in forum RDI - English
    Last Post: 3rd May 2006, 01:13
  3. diseq
    By anaconda_max in forum RDI - Satelit
    Last Post: 15th November 2005, 09:18
  4. diseq cu ss2??
    By xyboox in forum Placi DVB
    Last Post: 11th April 2005, 14:24
  5. ALT-DVB si diseq
    By TransWarp in forum Placi DVB
    Last Post: 3rd May 2004, 07:06
