Results 1 to 15 of 20
    pakistan
    Default dvb skystar 2 pc.Plz help a newbie
    plz somebody help me i have brought a pc dvb skystar 2 card
    only free to air channels can be viewed no scrambled channel viewable
    i downloaded dvb keys file from www.croteam-sat.com but i was not able to fix any thing .i wasnot knowing where to paste it the software version is technisat 4.3 and the other software is dvb viewer .plz can any body tell me about the exact procedure stepwise
    thanks alot
    Try Prog DVB and put the softcam.key file into the Plugins folder (you should have there the S2emu, too).
    Apr 2006
    Hotbird
    download the plugin for progdvb called s2emu, place the files in the root of progdvb (not the plugins folder, the main progdvb folder), then download the latest 'softcam.key' file- these are the key's. Place softcam.key in the root of progdvb as well. This forum contains a thread called 'channels viewable by pirate solution'- these will be the channels you will be able to watch. cheers!
    alt-dvb is optimised for skystar products. nevertheless, try dvbdream, progdvb, mytheatre and see which one works best for you. mytheatre is not free though.
    Quote Originally Posted by yuriythebest
    ... place the files in the root of progdvb (not the plugins folder, the main progdvb folder)
    Why in the root of progdvb? S2emu and softcam work very well in the plugins folder.
    Apr 2006
    Hotbird
    I tried placing it in the plugins folder at first but for some reason many channels would not open, could be just me though.
    May 2004
    for ProgDVB you dont have to put plugins in Plugin folder, just put them in ProgDVB folder, e.g. C:\ProgDVB but NOT in C:\ProgDVB\Plugins.
    but for other apps like MT, Alt-dvb etc you have to put them under plugins folder.
    PAKISTAN
    Quote Originally Posted by saed
    True. Saed brother but i always paste s2emu in plugins and then paste softcam key in progdvb parent directory
    the tutorial which i have posted in http://www.********.com/f2/viewtopic.php?t=4484
    OLDER versions of progdvb will let you put them on the root directory together with the softcam.key. now, newer versions of progdvb has implemented what others like dvbdream, mytheatre, etc has been doing for quite some time, to lessen the mess on the directory, and that is to put the emulation software under plugins (and all other plugins). with OLDER mytheatre, you even have to put your plugins under MDplugins, and use mdwraper on the plugins folder to use the emulation software.
    be it plugins or root folder, the end factor should be, you should be able to get it working. to each his own, i guess.........
    Apr 2006
    Hotbird
    boknoy_ph:
    true, true
    May 2004
    its not the problem of older or newer version, depends on progdvb.ini, where the plugin folder points to. you can manually change it also.
    yeps, indeed. the progdvb.ini will point your app to the correct folder (be it root or another folder). anyway... i will be gone for 40 days of holiday under the sun in philippines. so see you all
    May 2004
    Happy holiday Noy dear, come back soon, Bon Voyage..
    PAKISTAN
    Saed Brother what is the path of progdvb.ini file ? ..I cant findout this .ini file
    Bokony brother good luck..hope u will enjoy your Holidays :P
    Apr 2006
    Hotbird
    enjoy the holdiays!
  1. Vand Technisat Skystar 2 , Skystar 1
    By albatran in forum Shop
    Last Post: 30th September 2006, 17:05
  2. Help for a newbie
    By Seeking Satellite in forum RDI - English
    Last Post: 26th March 2006, 15:20
  3. nEWBIE---help!!!!!!!
    By TroyBoy in forum RDI - English
    Last Post: 3rd March 2006, 10:09
  4. Newbie and need help...
    By micron in forum RDI - English
    Last Post: 28th January 2006, 08:50
  5. Newbie Help!
    By stoney_111 in forum RDI - English
    Last Post: 25th August 2005, 12:04
