Results 1 to 9 of 9
    In a Weird RooM
    Default Help for Dvb Dream (SS2)
    i have a ss2 card and Dvb Dream software i installed the codecs etcetra for this i am able to scan all the channels on the dvb dream but i cant see the picture i can see these channels on Progdvb and altdvb but on dvb dream the screen is blank can somebody help abt it..?
    im attaching the pic also ...
    does the filter being used in dvbdream match the installed codecs? if you are using intervideo codecs, make sure you set the filter to intervideo on dvbdream too. could be plugins/softcam issue also.
    Apr 2006
    Hotbird
    what are the advantages of dvbDream over progDvb?
    In a Weird RooM
    i did install the codecs etc u mentioned above progdvb n altdvb are working fine ...the only problem is tht i cant see the pic
    and i just want to learn the software progdvb or anyother software better or not i cant say
    per experience, DVBdream has proved to have the lowest CPU usage on my box.
    In a Weird RooM
    i think altdvb takes less cpu usage than the anyother dvb application...
    In a Weird RooM
    brother im using intervideo and installed the latest plugins also but still the picture is not there ....signal is very gud on scanning if i scan a single tp it scans the channels but in picture it dosent show anything..
    if u look at the image above i attached the one signal is 100% and one is on 0% wt can be the problem..?
    although i can see more then 1000 channels names after scaning .... (without picture )
    from the other image you posted, you were using elecard codecs on the filtergraph, make sure elecard codec is installed.
    In a Weird RooM
    in the video option there are alternates intervideo ,cyberlink, elecard,
    i choosed the elecard for altdvb here it is intervideo...
    Quality 100% signal is 0%
  1. DREAM-500S VS DREAM-7020
    By polly75 in forum DREAMBOX
    Last Post: 4th December 2006, 23:07
  2. AU DREAM PATCH FOR EMETABOX USERS DREAM TV AGILA2 146E
    By irdeto2engineer in forum RDI - English
    Last Post: 6th June 2006, 23:41
  3. Dream ! Dream ! what happen?
    By yan naing in forum RDI - English
    Last Post: 20th May 2006, 15:55
  4. Replies: 1
    Last Post: 6th July 2005, 19:53
