    Apr 2006
    Default Strange Problem on HOTBIRD! Please Help
    12169 H
    12183 V
    12207 H
    12226 V
    12245 H
    12265 V
    12284 H
    I am using Hotbird. I have Neosat 1600+ . I have a very strange Problem which i cant understand. All the TPs (which i mentioned above) with H Polarity are Perfectly Visible I have more than 45% signal strength. but there is not a single signal on V Polarity.
    Does somone know why this Happens ? Is there any way to fix it ?
    andycapp
    Hi,
    Try turning your LNB about a quarter of a circle (90 degrees). Mind you, not the dish, only the LNB.
    AC
    Lahore
    Default Re: Strange Problem on HOTBIRD! Please Help
    Quote Originally Posted by usmanmr
    LNB has become faulty working with single polarity The remedy is to replace it with Supermax .5db
    Fte Max 100S
    Humax IRCI-5400z
    try turning on the lnb power to "on" from your stb setup. are you on a multidisecq switch like spaun? if your are, depending on the setting on the disecq, you may have to enable 22 kHz to on also. if all else fails, move your lnb as suggested, or change the lnb altogether.
    May 2004
    Kuwait
    Bofore moving ur LNB just try this
    Instead of 12169 H use this Frequency 12719 wih sr 27500 if u get the signals then boom i will tell u the remaining frequencies also.
    take care.
    Apr 2006
    Thanks for your replies Guys.
    I dont think LNB can be Faulty. I just purchased the complete system 1 week ago. I'll try to turn it as you guys suggested.
    LNB Power is ON, and I am not using multidisecq switch.
    Quote Originally Posted by lovebird
    take care.
    The Problem is with the Frequency of V Polarity. H Polarity Signals are OK. If you know something about V Polarity Frequencies, Please let me know.
    I complained this Problem to the Shop from where i purchased the System. The Guy there suggested to use 2 LNBS. Will that Help ?
    May 2004
    Kuwait
    OK for V frequencies try this instead of 12183 V
    use 11633 V SR 27500 OR
    12733 V SR 27500
    check the signals now it should work for U.
    take care.
  1. Strange problem........please help
    By scorpionz in forum RDI - English
    Last Post: 27th November 2006, 22:40
  2. Strange signal problem. Please help!!
    By selim_uk in forum RDI - English
    Last Post: 21st July 2006, 08:22
  3. Strange Problem
    Last Post: 21st July 2006, 07:51
  4. Strange Problem
    Last Post: 20th July 2006, 23:53
  5. help admin : strange login + post problem
    By superia4u in forum RDI - English
    Last Post: 13th August 2005, 14:49
