Results 1 to 6 of 6
    belpi23
    Default Problem on Technosat 1100
    Hi all,
    since the version 7.44 downloaded on www.dsrsoftware.com
    I can't upgrade the new software.
    With the two lasts version, my receiver doesn't have quality signal
    The strength is 70% but no quality.
    When I reinstalled 7.44 ver it's working properly but without polsat.
    Droshan - shelley, I'm sure that you can help me...
    Regards
    PI
    Satellite Internet Expert
    Default Re: Problem on Technosat 1100
    Quote Originally Posted by belpi23
    Hi all,
    Regards
    PI
    dear friend,
    as iam using 7.72 verion in my receiver and its ok with polsat.
    u may get this patch from the dsr site and transfer it to ur box hope it will be ok with signal and quality of ur receiver, by the way polsat is ok with it
    May 2004
    K.S.A (SRI LANKA)
    Hi all,
    Regards
    PI
    if you need previous S.w Versions thaen go www.satlover.com
    belpi23
    Thanks for your quick reply,
    I tried again and again dsrsoftware.com but no quality.
    It's not recognizing the disesq device.
    If I have to download from the droshan geocities site what about the password asked. This version will it be working for polsat ?
    Thanks
    PI
    May 2004
    K.S.A (SRI LANKA)
    Thanks
    PI
    go to www.satlover.com
    Guys,
    I have Technosat 5500SS-II, is there any relation between the signal strength and the software version used.
    I have installed the latest from dsr.
    Thks and I apprecaite your reply.
  1. technosat ts 1100 plus
    By salimust in forum RDI - English
    Last Post: 20th September 2006, 18:23
  2. technosat ts-1100 ver 7.58
    By georgekamal in forum RDI - English
    Last Post: 8th August 2006, 03:18
  3. TECHNOSAT 1100 plus S/W Working TPS OK
    By droshan in forum RDI - English
    Last Post: 27th November 2005, 12:28
  4. TECHNOSAT 1100 PLUS
    By lanvita in forum RDI - English
    Last Post: 12th November 2005, 11:12
  5. biz key to technosat 1100
    Last Post: 12th October 2005, 01:29
