    Alone_Moody
    Default Digital FTA USB External Satellite Receiver
    VisionDTV USB-Sat (StarBox)
    THIS IS ONLY INFORMATION NOT ADVERTISEMENT
    StarBox is an exquisite digital TV box, which offers an easy installation of USB & an amiable user interface; you can enjoy satellite TV in digital quality simply by your PCs or notebooks. Also, StarBox brings “Internet via Satellite” to your PC (service provider subscription required). You can enjoy surfing Internet at high download speed & never suffer from any delay!
    Software bundled with STARBOX:
    VisionPlus Drivers
    VisionData (for internet via satellite)
    Cyberlink PowerDVD 5
    Main Feature
    • Sharp appearance and easy plug-n-play installation
    With exquisite and sharp appearance, TwinhanDTV StarBox provides an easy installation by USB plug-n-play. The high speed USB 2.0 transmission provides superb video quality without ghost and snow.
    Watch digital satellite TV on your PC
    Receive free-to-air digital satellite TV and digital radio station on your PC. TwinhanDTV Sat is aprofessional DTV receiver, which brings digital satellite TV and radio to your PC. With TwinhanDTV Sat, you can experience the high definition & crystal clear video quality (HDTV) easily through your monitor.
    Listen to digital radio
    Enjoy the digital satellite radio stations in stereo & playback any time you like. The audio effect is near CD quality.
    High speed Internet via satellite
    To use "Internet via satellite" service, you need to have an account from satellite Internet serviceprovider, plus an account with a local Internet Service Provider. First, you connect to the Internet via your local Internet Service provider. Secondly, you log on to your Satellite Internet provider. If you are sending a request for a specified web page, the request goes via your local provider to the Satellite provider. They will retrieve the Internet data and send this specified web page via Satellite back to your Computer. The download speed depends on the satellite ISP provider.
    Direct Burn into DVD
    Direct record your favorite TV programs into DVD format without saving them in hard disk in advance.Just press “Record” button and software will start to burn live programs into your DVD. When the program ends, the DVD making is finished.
    Wake Up Scheduled Recording
    Just set your recording schedule in advance, the computer will execute the recoding job automatically even your PC is in sleep mode!
    Feature List
    • Digital TV & Radio receiving (DVB-S)
    Watch digital satellite TV programs on your PCs
    Listen to digital stereo radio
    Support DiSEqC 1.2 & USALS
    • High Definition & Crystal Clear Video Quality
    Support HDTV receiving
    4:3 & 16:9 selectable aspect ratio
    Experience best video quality at high resolution up to 1080i
    • Internet via Satellite
    DVB data service
    High download speed via satellite bandwidth
    • Personal Video Recording
    Instant & schedule record programs as MPEG II format
    Wake Up Schedule Recording
    Time-Shifting
    • TV Function
    SAP (Language option)
    Electronic Program Guide (EPG)
    Transponder, region, and Frequency range Auto Scan
    Multiple Frame Capture
    Parental Control Password
    Multi Channel Preview
    Favorite List
    Hot Keys
    • Others
    Video Quality Adjustment
    Full function Remote Control
    DVB Teletext
    Specification
    Tuner
    • Input Terminal: F-type 75 Ohm
    • Receiving Frequency: 950~2150 MHz Tuning Range
    • Input level: -65~-25dBm
    • Carrier Capture Range : ±5MHz
    • Ambient Temperature: 0°C to +70 °C
    • Support MCPC and SCPC
    QPSK & FEC • Symbol Rate: 2~45Msps
    • QPSK filter: Root-raised cosine filter with roll-off 0.35
    • Punctured codes: 1/2,2/3,3/4,5/6,7/8 and Auto
    LNB & Switch control • LNB Supply Voltage: 13V/18V with Short Circuit Protection
    • DiSEqC: 1.2
    • Support Data Burst & Tone Burst
    • Antenna and LNB Control: 22KHz Tone
    • Max. LNB Supply Current: 400mA
    USB Interface • Universal Serial Bus 1.1 / 2.0 Standard
    • B Type USB Female Connector
    De-multiplexing • Max No. Section Filtering: 32PIDs
    • Engine: Hardware
    • Stream Capture: PES &TS
    A/V Format • Video Format: MPEG-II Main Profile& Main Level
    • Audio Format: MPEG-II Audio Layer I & II
    System Requirements
    • Microsoft® Windows® 2000/XP
    • Microsoft® DirectX9.0C or later
    • Microsoft® Windows® Media Player 9.0 or later
    • P4 2G MHZ CPU or above
    • 256MB RAM or above
    • VGA card with at least 32MB memory
    • Sound card or on board sound chip
    • One free USB 1.1/2.0 port *
    • Digital Satellite Dish & LNB
    * Note: When your USB port is 1.1, you could not receive HDTV format TV programs.
    Retail package
    • TwinhanDTV StarBox
    • Infrared remote control with AAA batteries
    • Infrared remote control receiver
    • Quick Installation Guide
    • Software CD (Multi-lingual application
    software and User’s manual in PDF format)
    • USB cord
    Indonesia
    It looks nowaday's that rdi is an advertisement place
    Terrorist use the muslim faith for there privat intrests, and should be killed more painfull than their victems
    nopes, only the admins and mods are not quick enough to filter out these kind of posts.
    anyway, back to the topic, it seems the usb version of twinhan is not yet supported in most dvb applications like mytheatre (anybody feel free to re**** this idea). once it goes mainsteam, then only it will be supported. as it is, you can only view FTA signals if no plugin will work.
    FACT: you need a very fast CPU to exploit the HDTV functions of a dvb-s device since it will eat up all your CPU cycles. even those decoders with onboard mpeg decoders suffer this kind of tragedy since the crunch of decoding HDTV signal is passed on to your CPU from the onboard mpeg decoder. i suggest a p4 3.2 dual core, or AMD equivalent with very good codecs installed, preferrably nvidia.
    now, admins...mods, will you kindly look around at what is happening to this forum? edirect has been chastised for promoting FREE items here and he is even a legal sponsor of this forum. how much more for these freeloaders? RDI admins, wake up
    Alone_Moody
    yeah right, talk to the marines.
  1. No.1 Digital Satellite Receiver
    By walkonwater in forum RDI - English
    Last Post: 28th May 2014, 14:30
  2. Replies: 4
    Last Post: 29th January 2008, 20:28
  3. HUMEX Digital Satellite Receiver
    By JPS in forum RDI - English
    Last Post: 9th November 2006, 09:27
  4. How to tune/setup a Digital Satellite Receiver
    By tango in forum RDI - English
    Last Post: 12th June 2006, 18:31
  5. How to tune/setup a Digital Satellite Receiver
    Last Post: 11th June 2006, 08:44
