Results 1 to 6 of 6
    Pakistan
    Default Please Solve My Problem
    Dear RDI Friends,
    I have Star Track Nc 709 Ci STB. I have connected it with a DISEQC
    for C/KU band.My problem is when I switch to C band satellite or channel
    my receiver works fine and it performs all functions. But when I Try to switch to KU band my receiver turns off and it also makes my DISEQC switch out of order and burns it.
    I Tried direct C and KU cables attach to RF of my STB Separately or one by one.
    The result is Same. C band works fine but as for as Ku band ,it switches STB off and does not Turn on untill I disconnect my Ku band LNB cable.
    Is it my Recevier Fault or Ku Band LNB is out of order
    OR it is DISEQC Switch problem
    Please help me and solve my problem.
    Wattoo
    Lahore
    You didn't check by replacing the KU band LNB?
    Fte Max 100S
    Humax IRCI-5400z
    Nov 2005
    Aslam o Alaikum
    Masood is right. You should change your KU band LNB.
    Dear Mathila Your Ku band LNB have some short point from inside or your cable which you are using for Ku band LNB is short. So first check your cable and if it is ok then change your Ku band LNB your problem will be solved.
    Lahore
    DiSEqC switch burns in only the case if coaxial cable's both wires are meeting at one point ,,short circuit with F type connector
    Plz recheck your connections
    Fte Max 100S
    Humax IRCI-5400z
    Pakistan
    Default Thanks every body
    Thanks Friends. My KU band cable was burn and short circut , I changed it all is OK.
    Thanks
    Wattoo
  1. HELP NEED TO SOLVE MY PROBLEM
    By skycom in forum RDI - English
    Last Post: 17th October 2006, 03:26
  2. Replies: 2
    Last Post: 14th September 2006, 23:50
  3. your help invited to solve opentel 4000CIR problem
    By chuppan in forum RDI - English
    Last Post: 6th January 2006, 19:46
  4. find somebody to solve indo TV7 problem
    By pjerry7799 in forum RDI - English
    Last Post: 6th December 2005, 11:32
  5. Can some one solve my problem.Help me plz
    Last Post: 19th May 2005, 06:38
