Results 1 to 3 of 3
    Default a little help please !
    i am having all kind of trouble with the polsat keys:
    i tried many keys (claimed to be the latest) and none of them worked. i don't know what is the problem, maybe my receiver ( OPENBOX F-100) or the software for nagra in it (ther'es 4 lines for each provider, for 7101 for example i enter the first 16 digits with 00, and in the 2nd line i enter the following 16 digits with 01, which leaves two lines free for 7101).
    now i tried the following:
    N 7101 00 5321A68A7D09CA52
    01 A52CC8C3A533A4A1
    both with 7101 and 7001 and tried also 11 instead of 01 for the 2nd key
    another one
    key=00 AE20B1D2EC404ECB
    key=01 A19A56B86F2E2331
    and
    another !:
    7001:
    Key 00: 0A A3 12 42 62 5E 2C 2C
    Key 01: 5A 86 00 D1 F9 E9 3B 33
    and another :
    01KEYS : BA DF E5 63 9F 6A 8B A9
    11KEYS: E9 1B 93 10 70 8C B3 1D
    but none of them worked.
    please i'm desperate at this time and i need your help !
    tell me weither the keys are wrong or the way i'm entering them.
    thanks.
    Nov 2005
    sometimes I have to repeat the keys on lines 01-0 and 0-11. The keys you are using (0-00) BA DF etc. (0-01) E9 1B etc. are correct Good luck.
    Lahore
    Default Re: a little help please !
    Quote Originally Posted by G E R
    i.
    Unless you upgrade with Nagra2 ok s/w ,keys won't work
    Fte Max 100S
    Humax IRCI-5400z
