Results 1 to 6 of 6
    Default key problem 5400
    hi all,
    I have a problem with keys-most of the time the receiver 5400z isnt taking the keys(the keys load then there is a verification error)and of course the channel remain closed I have to enter the keys by hand from the remote control.sometimes tghough without changing anything the keys are uploaded smoothly-any ideas?
    also if ne1 is capable to help-when I switch from tps to digital+ ie taquila the pic freezes and I have to switch off and on again-yesterday I had this idea that maybe I am missin some module so I uploaded hot6.4 and continued updated to date ie 7.1- I was succesful the receiver ran perfect but when I went to turn it on in the evening the same problem reoccurred
    Try to use Samy_Humy_Edit to load the keys.
    no-the same
    Apr 2005
    Lahore
    Default Re: key problem 5400
    Quote Originally Posted by rod905
    hi all,
    I was facing the same problem while I tried to load a not vairfied version 6.6 to my box and it made me mad
    camelot was also suffering with same desease so I had to work a lot to overcome the problem,,the solution was I upgraded with ToH3.3 HoT6.5 and latest keybin from Mach1 files ,,,,you may try it and later upgrade with HoT7.1
    Fte Max 100S
    Humax IRCI-5400z
    Jun 2005
    Australia
    rod905
    If you can insert keys into your humax receiver it would be a 5400.
    A 5400z is an original box without UCAS capabilities.
    cheers weirdo
  1. Humax 5400 problem
    Last Post: 12th May 2006, 00:12
  2. humax 5400 problem
    By jim in forum RDI - English
    Last Post: 20th January 2006, 15:31
  3. HUMAX 5400 PROBLEM
    Last Post: 6th January 2006, 03:32
  4. HUMAX 5400 PROBLEM
    By stefen in forum RDI - English
    Last Post: 17th November 2005, 00:44
  5. humax 5400 z problem
    By leventenagy in forum SD Receivers
    Last Post: 12th September 2005, 23:57
