Results 1 to 3 of 3
    Jan 2003
    Italy
    Default Problem about hot 6.9
    I can't load on my humax new firmware from my laptop because it hasn't serial port, so I can't join laptop to humax through null modem cable. In Italian forum section a kind person told me that exists a software emulating serial port on USB port. Can anyone help me to find this software? Thanks and best regards.
    Lahore
    Default Re: Problem about hot 6.9
    Quote Originally Posted by spot1bay
    As kroky advised you already that you will have to check many adapters as most of adopters don't support STB's com ports
    I personally had this experience
    Fte Max 100S
    Humax IRCI-5400z
    May 2004
    its not realy a software, its a dongle/adapter kind of thing which converts your USB port to a COM port so you can connect your hummy to a laptop where there is no COM port but only USBs are there.
    the software which he is referring might be the driver to this adapter/dongle.
    not all such adapter will work in your laptop, you have to try different model/make which suits you. you will be lucky if the 1st adapter you purchases and it works.
    have a look at the picture how it looks like
  1. VERY SERIOUS PROBLEM.
    Last Post: 27th July 2006, 02:16
  2. Log in problem
    Last Post: 18th November 2005, 17:12
  3. problem with ECM
    By raphex in forum Placi DVB
    Last Post: 15th November 2005, 13:51
  4. @ problem
    By msalman in forum RDI - English
    Last Post: 30th July 2005, 08:13
  5. Problemă !!!
    By skycleaner in forum DTH & Cable-Romania
    Last Post: 20th July 2005, 17:22
