    In a Weird RooM
    Default Help abt Ss2 technisat card n alt-dvb
    i have bought a new card SS2 technisat .. few days ago im trying to scan the channels from prog dvb , alt-dvb, n dvb-dream but in vain in alt-dvb2.1 it scanned some channels but its giving a graph error i dont know wts wrong wid it....helpppppppppppppppp. lol. thanx in advance..
    May 2004
    set the correct lnb/satellite & frequecny values in setup of progdvb, if everything is correct you will surely be able to scan the channels.
    To avoid Graph error, install Cyberlink PowerDVD or InterVideo WinDVD.
    dead sea
    dear sir saeed
    its been 3 days i am asking the same question , i got my ss2 a few days ago n sorry to say no one helped me out i got help some how from other sources i am using mytheater n prog dvb but unable to get any video from altdvb...........problem is the same graph error or direct show error i installed video decoder as well . can u plz tell me where to install that decoder cyberlink or anyother in altdvb folder or in c programe files.
    secondly i got some pluginns n everything is working fine in progdvb but same channels not working in mytheater like some channels of polsat n xplustv,inxtc is fine. whats the reason do i need some diffrent plugins for mytheater.
    i am lookin fwd that u help me out this time .
    thanks
    ciao
    In a Weird RooM
    how can i get the plugins and codes like inxtv or xplus or othersany site plz..
    May 2004
    this is how you put plugins
    for any kind of plugin, you can put in c:\ProgDVB main folder and it will appear under Plugin menu in progdvdb, for keys/codes you have to put softcam.key or other key file in the same c:\progdvb folder too.
    For MyTheatre and ALT-DVB, you have to put plugins in c:\MyTheate/Plugins and C:\ALT-DVB\Plugins folder respectively.
    This is how you scan the channels in ProgDVB
    to scan channels, 1st goto Setteing-> Desiqc menu there set you satellite settings. then from menu "Channel List->Channe Search" you can scan channels.
    To resolve the Graph filter error, you dont have to put anything in ALT-DVB, you need to install another software separatelly. Normally we install an MPEG-2 decoder/codec, but for easy going just install CyberLink PowerDVD software or Interlink WinDVD software it will automatically install the MPEG-2 codec/decoder in the system and thats how your graph filter problem will be solved.
    May 2004
    Quote Originally Posted by baba4u
    from here
    http://www.********.com/uploadshow.php?id=2
    and here
    http://www.********.com/uploadshow.php?id=11
    In a Weird RooM
    im tryin to learn dvb-card very quick..thanx for ur kind help..
  1. rec, technisat blocat
    By xud in forum SD Receivers
    Last Post: 31st October 2006, 22:57
  2. TechniSat DVB
    By white2 in forum Placi DVB
    Last Post: 19th June 2006, 18:37
  3. Technisat DVB+PCTV Star pci card
    By Rizi in forum RDI - English
    Last Post: 5th March 2006, 15:30
  4. technisat 4.2.2 vs 4.2.10
    By khristian in forum Placi DVB
    Last Post: 24th April 2004, 18:19
  5. TechniSat Update
    By clauss in forum Placi DVB
    Last Post: 4th September 2003, 03:00
