    italy
    Default FRIENDS,WHY NT HELP A SMALL TECHNICAL PROBLEM?????????????
    we want to use RF signal (Output of reciever) UHF far 390 meter.use Coaxil Cable RG6/U 75 OHMS
    UHF.
    I Use UHF AMPLIFIER 16db, 1 Input 4 out 3TV OUT PUT+1 OUTPUT DIRECT.ALL Out Put Occupied I Connect UHF DIRECT Out Put . IN THIS CABLE I Have 2 JONT. Source Then 20 Mtr JOINT+350 +20 meter 2nd joint then T.V. if i buy two UHF Amplifier and fixed on joint place Can it work? like thist Amplifier+20mtr Than Amplifier+ 350mtr Cable+ Amplifier +20 mtr=T.V. is this o.k or not.Mean to say Joint Place Fixed Amplifer.
    Audio/Video
    i connect in Video out put 390meter Cable other end i recieve 100%Clear.
    as i told u i used Coaxil Cable RG6/U 75 OHMS. So for Audio it is very Difficult to Pull another cable. IS THERE SOME THING AVAILABLE LIKE FOR EXAMPLE I TAKE AUDIO/VIDEO FROM THE RECIEVER IN THE MOUDULE THE Coaxil Cable RG6/U 75 OHMS THEN OUT AGAIN MOUDULE
    FROM THIS OUT PUT TAKE TO T.V.INPUT
    Default Re: FRIENDS,WHY NT HELP A SMALL TECHNICAL PROBLEM???????????
    Quote Originally Posted by hummy
    UHF.
    >>> Above is OK!
    Audio/Video
    >>> Not possible, use setup above (using RF).
    italy
    u dnt know any thing. u r dull mind. Give Answar insted of nt give answar?
    Apr 2004
    Germany
    before acting stupid like u did above why don't u search in google
    BTW i gave u the answer but somehow u felt it's better to open 2 threads
    http://www.********.com/f2/viewtopic.php?t=59908 here is ur answer
  1. TECHNICAL SECTION ABOUT JTAG FOR NEWBIES
    By yan naing in forum RDI - English
    Last Post: 19th May 2018, 20:47
  2. HIVION TECHNICAL FORUM IS THERE ANY
    By newone in forum RDI - English
    Last Post: 25th June 2007, 20:59
  3. Dodi and Friends please help me to resolve my problem
    By valiyana in forum RDI - English
    Last Post: 5th July 2006, 21:16
  4. Small Question !?
    By Minitechnikus in forum DREAMBOX
    Last Post: 12th November 2005, 14:12
  5. technical question about Xsat receiver...
    By jelebu in forum RDI - English
    Last Post: 15th August 2005, 17:57
