Results 1 to 2 of 2
    Banned
    Default Power Video Converter v1.5.11
    Power Video Converter is a versatile and very easy to use tool for video conversion, joint and split. It support convert between AVI, MPEG, WMV, VCD, SVCD, DVD, VOB, DAT. Use it to convert your media files to mpeg (in DVD, SVCD or VCD formats too), to AVI (including the DivX format) and to Windows Media Format. It also enable you to joint some small media files to one in every format and you can split a large film to some small pieces of films. Power Video Converter has a multi-tasks system, which enable you do different tasks (convertion, joint, split) at one time after performing a single click.
    Features includes:
    # Extreme fast Conversion speed;
    # Supports AVI, Divx, xvid, MPEG1, MPEG2, ASF, WMV, VOB, DAT;
    # Batch file conversion;
    # All supported formats to MPEG1;
    # All supported formats to MPEG2;
    # All supported formats to VCD,SVCD,DVD(PAL,NTSC);
    # All supported formats to AVI(DivX,XviD, MPEG-4);
    # All supported formats to Windows Media Format (support custom wmv profile);
    # Joints video files to a large one;
    # Splits large video file to smaller clips;
    # Specifies start and end position while convert and joint;
    # Extract sound from all supported formats to mp3, wav, wma;
    # Extract images from all supported formats to bmp;
    # Backup DVD Disk(.VOB) to all supported formats;
    # Backup DVD Disk(.VOB) music to mp3, wav, wma;
    # Backup VCD Disk(.DAT) to all supported formats;
    # Backup VCD Disk(.DAT) music to mp3, wav, wma;
    # Create custom wmv profile;
    # Load custom wmv prfile.
    http://www.apussoft.com/powervideoconverter.exe
    Serial: 1584B92C-44F5297E-6C4AED2E-5CB92F19-534A1E63-DE414D4A-D050FF0D-3CC5B5A1
    Serial: C64E4F93-6C6AB63D-68ECA536-FA7CCF74-43030BBA-0369A37C-D472329E-329230C8
    Timisoara
    man, mie nu imi merg serialele astea.
    Adica imi spune ca e registered, dar daca dau sa scoata sunetu din ceva ce trag de pe sat (pinnacle+progDVB) imi scoate doar o parte.
    La fel imi face si daca vreau sa convertesc .. imi converteste doar o parte din fisier.....
    Desi zice ca e registered se comporta ca si cum e trial
  1. #1 Video Converter v4.1.3
    By Unuseroarecare in forum DVD - DIVX - HIFI
    Last Post: 4th March 2006, 18:30
  2. Power Video Converter v1.5.9
    Last Post: 18th February 2006, 13:02
  3. Power Video Converter 1.5.8
    Last Post: 3rd February 2006, 05:40
  4. Video Converter Plus v3.01
    Last Post: 26th January 2006, 20:20
  5. Power Video Converter 1.4.4
    By nrares in forum DVD - DIVX - HIFI
    Last Post: 29th June 2005, 12:50
