    Antonyo
    Default Nokia 9800S Help !!
    How to upgrade nokia 9800S
    Any can help.
    :lol:
    And which is the best smart cards for it and also Program machine.
    Thanks a lot,
    Antonyo
    Australia
    What software version have u got on your Nokia 9800s?
    If it is MA 2.0, forget upgrading it,Nokia abandoned this model.
    If it's MA 1.1 to 1.3 you have to leave on one of the frequencies on Hotbird or Astra sats and leave the receiver on-it will automatically upgrade to MA 2.0.
    Antonyo
    Default nokia 9800s
    Thanks alot.
    But I do not know which Softwar the Nokia 9800S .I looked in Gatalog but there is nothing about that
    But my questio is follow:
    1- As I told you that I have Nokia 9800 S
    If I pay smart cards like fun, titanium ……with program machine likes Dynamite plus as in www.duolabs.com.
    The question is this correct way to program the smart card?
    then I need write program to add the keys!
    And anther question should I upgrade nokia 9800 S also.
    So. Pl, tell me if you good www where can I know how to program the smard cadrs for nokia 9800 S step by step.
    Next anther idea I heard
    For a programmer you need a Phoenix, this can programm all cards
    used in that matter.
    You will have to go to some SatTV Board and inform you what
    emulation software is out for what card ... this stuff changes
    often ... it is a hunting game.
    The best would be dreambox, or a TrippleDraggon, or a dbox2, and try cardsharing.
    So should I pay drambox and try cadsharing
    Pl, your help will be great.
    Thanks,
    Antonyo
    NOKIA 9800 can not be used to program any card, you may use the card reader to read original or pirate cards.
    Antonyo
    Default how can !
    How can I make programm for the samrt card then use it in Nocia 9800S
    also you have good idea about write programm.
    Thanks,
    antonyo
    Australia
    You have to do a lots and lots of reading to undestand how to program a smartcard,No one will give it to you on a Silver Platter.
    If I show you how to program a card,I would have to charge you $$$$'s
    There are a lot of files on the net you can put on the card but it depends which channels,satellites you want to experiment on your card.
    Antonyo
    Default nokia 9800s
    Pl, I want to programm alot of Chanales:
    like :
    ART.
    Xplux.
    Dream
    Free XX
    SCIT
    so tell my your suggestion about hwo to make programm the cards for Nokia 9800 S.
    MFG,
    Antonyo
  1. NOKIA 9800S
    By palinca de bihor in forum SD Receivers
    Last Post: 7th July 2007, 16:02
  2. nokia 9800s !!!
    By graty99 in forum SD Receivers
    Last Post: 24th March 2006, 10:43
  3. RECEPTOR NOKIA 9800S MM
    By ADYSAN in forum SD Receivers
    Last Post: 18th February 2006, 15:57
  4. nokia mediamaster 9800s
    By nirolf in forum SD Receivers
    Last Post: 30th December 2005, 13:54
