Results 1 to 14 of 14
    In everybody's heart
    Default Card sharing required speed
    What is the required speed for card sharing 128 Kbs or 256 kbs
    and also kilo bytes per second speed.
    May 2004
    Default Re: Card sharing required speed
    Quote Originally Posted by wiseguy4u
    data for cardsharing is very small data and not much big, even a dial-up of 33.6kbps will work. (3~4 KBps)
    Apr 2005
    just in case for dial up, do I need to connect in the internet always to receive the data for card sharing or I will connect only just in case there is a change of code?
    May 2004
    you have to be connected ALLWAYS, it is just pretending that you have the original smart card installed in your system, if you disconnect it is similar to removing the smart card from your system. thats all.
    Pakistan
    Saed Brother Can U plz tell me that Card Sharing work with Sky Star 2 DVB Card? If not then Which card is better for Card Sharing?
    yes u can use skystar for cs just use wincs or other plugin for cs
    Quote Originally Posted by Farman
    any card that accepts cs plugin should let you do the job. it is important that you have a constant and reliable connection to the internet.
    I have 56K Dial-up if there are fluctuations in speed will the channel
    freezes or it will stop working.
    May 2004
    Yes, all dvb cards which supports 3rd-party app's like ProgDVB, mytheatre etc (or MD-compatible plugins) supports card sharing. and SkyStar-2 is one of the most compatible card.
    May 2004
    if you loose data receiving then your channels will freeze for sure, but as there will be a data flow again then channel will run properly
    jakarta
    Saed minta alamat server yang aktip yg providernya bisa diterima di indonesia ( saed pls send me server active for receive any provider in indonesia ) matur suwun.
    Apr 2004
    Dubai / UAE
    Default DVB Card Sharing
    I reading in some other posts that Skystar 2 supports card sharing because there is a chip onboard capable of that. The post also says in case we use other cards like Twinhan compatibles, we have to use some additional plugins. is it correct ? can somebody help giving a brief how i can use my Twinhan Card for card sharing ? At present any encrypted channel is available on hotbird for card sharing using dvb ?
    thanks in advance
    May 2004
    Default Re: DVB Card Sharing
    Quote Originally Posted by thasnim
    thanks in advance
    Cardsharing is not a feature of built-in chip on any card. it is based on a plugin. All those dvb cards (including ss-2, twinhan) which supports third party app's (other than their own software) OR if their original software supports MD-Compatible plugins then they can work for card sharing.
    SkyStar-2 and Twinhan both supports the cardsharing in the same way. no difference. it is just a software plugin which they both use.
    May 2004
    Quote Originally Posted by joyosuro
    maap, ora ono pak. (sorry, i dont have one. )
  1. Replies: 4
    Last Post: 11th January 2011, 22:18
  2. CBN 45E CARD REQUIRED
    By zafarjoia in forum RDI - English
    Last Post: 23rd February 2007, 19:37
  3. CBN 45E CARD REQUIRED
    Last Post: 14th March 2006, 22:32
  4. PCI card sharing ! Experties Required ?
    By Ali4u in forum RDI - English
    Last Post: 23rd June 2005, 09:06
