Results 1 to 3 of 3
    Sep 2003
    Default Probleme scanare transpodere cu Progdvb
    Mi-am cumparat curand de la Caro o placa PC de receptie satelit AVerTV DVB-S( http://www.avermedia.com/cgi-bin/pro...tuner_dvbs.asp) .
    Cind dau sa scaneze cu ProgDvb, gaseste cel mult 6 transpodere. Apoi scaneaza in continuare dar nu gasegte nimic. Imi tine si procesorul In full load. Pe lista de placi suportate pa site-ul progdvb http://www.progdvb.com/ este si placa mea. Cu softul original scaneaza tot.
    Am un calculator cu Athlon64 3000+ 2 giga ram.
    Merci anticipat.
    TIMISOARA
    www.kingofsat.net .. cred ca e necesar un update la transponderi ..
    Daca asa nu merge .. incearca sa iei ultima versiune la Prodvb
    Sep 2003
    Pana la urma am copiat o lista de canale de pe toti satelitii in folderul ''Channels'' din ProgDvb si e OK. Fara sa mai dau scan .Orice as fi facut scana doar 5-6 transpodere.Astept o versiune noua ProgDvb.
  1. probleme progdvb
    By ciortuz in forum Placi DVB
    Last Post: 29th June 2006, 10:21
  2. Probleme cu progdvb
    By gavrild in forum Placi DVB
    Last Post: 23rd February 2006, 16:12
  3. progdvb probleme
    By olimpicSAT in forum Placi DVB
    Last Post: 24th June 2005, 11:00
  4. D+ 11097 scanare cu ProgDVB
    By horatiu74 in forum Placi DVB
    Last Post: 13th January 2005, 09:59
  5. Replies: 0
    Last Post: 29th August 2004, 16:23
