Results 1 to 15 of 15
    Nov 2005
    sialkot
    Default ASIA sat3 ,thaicom2,3 And pas 10
    i have 240cm dish .can i get these three setup on one dish.
    if yes plz any body guide me with picture,or any other method.
    i am very thankful to u.
    skystar2,pas10/7,asia sat3
    0821099849311
    Lahore
    Default Re: ASIA sat3 ,thaicom2,3 And pas 10
    Quote Originally Posted by shehbaz
    The method has been discussed many times ,,however plz wait for Asifde to show you "display" of one dish with many LNBs
    Fte Max 100S
    Humax IRCI-5400z
    Dear shehbaz you can get idea for your required setup with the help of this picture,
    http://img137.imageshack.us/img137/3694/meshdish9gj.jpg
    In this picture centrel LNB is for Thaicom 3, LNB first from left side is for Asiasat 3S and the LNB first from right side is for PAS 7/10.
    I hope you will have a good idea about where to fix LNBs for your require satellits through this pictures If there is any problem you can ask more.
    @ sir masood You can also get help for your require setting through this picture. This is enlarge picture which you was asked few days ago.
    Feb 2006
    Dear asifde, Pls help me how to set up LNB can get Pas 10, ST1, Asiasat 3s and Telkom on 1 dish. Thanks.
    Nov 2005
    sialkot
    thanx very much asif bhai,
    really good helpful pic for me.
    thanx............
    0821099849311
    Quote Originally Posted by vnat
    Dear vnat getting of Telcom with PAS 10 is a little dificult work. I dont know about signal quality of Telcom in your area, here we are not able to receive it even by kepping dish center on it on a 8 feet dish. But if you have good signal quality from telecom then you can try this combination by keeping dish center at ST 1. You have to put LNB for PAS 10 on the right side and for Asiasat 3 and Telcom on the left side(if you are standing infront of dish). First put LNB for asiasat 3 on the left side then put for telcom near the Asisat 3 LNB on its left side. Through this setting you may have some problems with signals of some channels from PAS 10 but it is nesessery to include Telcom in this combination.
    Feb 2006
    Dear asifde, thank you for your information. In my location, Telkom have
    strong signal ( 80 up ), Pas 10, ST1 and Asiasat 3s same also.
    I will to try do it with your instruction. Thanks again.
    May 2009
    Default setup
    Dear Sir, Mr. asifde
    can u Pls show me how to set up LNB can get Pas 10, ST1, Asiasat 3s Thaicom and Telkom on 1 dish. Thanks.
    Email: ******@yahoo.com
    Jun 2006
    Thailand
    Quote Originally Posted by vnat View Post
    what is your position?
    SATELLITE GURU Expert
    Quote Originally Posted by wombat View Post
    It can be done Wombat with say a large 4m dish in certain countries.
    I cannot do all on one dish. However I can use a 3m or a 4m dish for Thaicom5 KU and DSTV Cband... and still keep signals in heavy rains from Thaicom which is pretty weak where I am.
    For those in China as you know in most places not possible to get Thai.
    Unless you use a HAVA.
    Jun 2006
    Thailand
    Quote Originally Posted by irdeto2engineer View Post
    yes, i agree. but for precise advise his position should b know otherwise some lnb's might end on the wrong side of the dish center
    Yes but there can be a lot of ds loss so not worth it unless you are in the prime location to do it... in India it might be possible.
    I only used fixed dishes primed for each satellite and always go above the minumum size required so that I dont have rain fade in the Typhoons.
    One Hava customer in Dongguan has friends visiting right now as their small 60cm dishes on Dream TV just lost signals in the rain.
    They are amazed his channels work in the rain or in Typhoons which are over the Philppines right now. lol
    So Wombat, when your Dream TV conks out due to storms in the Pines mine are not affected. Dream is out now again.
    Jun 2006
    Thailand
    Apart from the Typhoons, the hacksat keys are working fine )
    Yes on some sats... but maybe not for much longer on dream tv
    Member Teacher
    Oct 2008
    Default pls..
    Quote Originally Posted by asifde View Post
    Sr. asifde, please show the big picture here.. I'm interesting on it..
    Thankssss
  1. ASIA SAT3 KU
    By superia4u in forum RDI - English
    Last Post: 31st May 2010, 18:14
  2. Replies: 3
    Last Post: 4th September 2006, 18:45
  3. ASIA-SAT3 channels going blank
    By satpalchat1 in forum RDI - English
    Last Post: 22nd June 2006, 08:32
  4. MRTV 4 at thaicom2,3
    By ye2 in forum RDI - English
    Last Post: 2nd February 2006, 18:35
  5. Zee TV Asia Pacific, Zee Music Asia and Zee Punjabi on PAS 8
    Last Post: 12th November 2005, 19:05
