Results 1 to 11 of 11
    bjv
    Default Problems in receiving Insat 2E
    Hi All,
    I am facing a problem in receiving channels from insat 2E 83 degrees. My setup is like -
    I and my friend together has 2 dishes, with hotbird in my dish and Insat in my friends dish. Insat is splited by 1 x 2 splitter. Each goes to two different switches of myself and my friends. Hotbird lnb is with dual out, one comes to my switch and other goes to my friends switch.
    Since 4 days I am not able to get Insat , but getting hotbird without any problem. My friend is receiving both hotbird and insat without any problem. I swapped connection in my switch, but no difference. I changed the splitter for insat, still no difference. Could somebody please help me in this problem.
    I checked all the connections in the splitter and switches, everything is in place.
    Thanks,
    BJV
    Nov 2005
    sialkot
    i have same problame.i have also asiasat3 and insat2,3 with difirent
    dishes.On asiasat3 have daul lanb and other singal 5150.
    i have 2 reciver.1 have 2floor and 2 is in the basment.
    wich is reciver in the basment it.s have all control.i mean when i see 2 reciver on asiasat3 .1st reciver didnot work on insat2,3.asiasat working fine only v chanls. but when i open insat3 in basment asia3 didnot work on the 1st floor.and also asia 3 channel v and h are working same time.
    plz help us...........................if u don,t understand plz ask again.
    skystar2,pas10/7,asia sat3
    0821099849311
    Default Re: Problems in receiving Insat 2E
    Quote Originally Posted by bjv
    Hi All,
    Thanks,
    BJV
    Must be magic, pray my son, pray
    bjv
    Default help
    Hi Everybody,
    Could this be due to any problem with my cable.
    Thanks.
    Bjv
    Lahore
    As I replied thru PM that splitter is not the device to share one dish with two STBs.
    Fte Max 100S
    Humax IRCI-5400z
    bjv
    Default help
    Hi Masood,
    Thanks for your reply.
    But I have been using this setup for nearly an year without any problem. I dont know if the device what I use is called splitter. It has one input and two outputs. Later it going to a diseqc switch to join with my hotbird and comes to STB.
    Any suggestions.
    Regards,
    Bjv.
    az30094
    Using a splitter is a bad idea in Satellite TV reception. It may seem to work for sometime. But sooner or later, you start facing problems, including damage to your hardware.
    Basically, only one device (receiver or a DVB PC card) can be used at one time.
    Dual output lnbs is the answer.
    bjv
    Default help
    Hi All,
    Could it be from the receiver. Beacuse now I am getting signals for half hour, sometimes 10 mnts like that and again no signal. But no problem with hotbird, it has continous good signal.
    Regards,
    Bjv
    Feb 2006
    Default Could anyone help me out with Zenega STB crcaks
    Hi guys,
    i wonder whether there is a crack for zee tv zenega stb to access all the channels for free? I have heard that there is such a crack but couldnt get it till date. STb has a serial port and i think the STB can be cracked to get free access to paid channels?
    Also apart from the channels zeetv provides can i get some other free channels by changing the orientation of the dish?
    please guide me in this regard.
    kumar.
    Bangalore India.
    :P :P
    May 2004
    allmost every receiver has a serial port but it doesnt mean we can crack it. Zenega/Zee is not yet cracked.
    yes, if you move your dish you can wacth more channels on other satellite but you will loose zee. and i am not sure Zenega allows you to scan other than zee.
    bjv
    Default succeeded
    Hi All,
    I found out the problem and cleared. It was from my Diseqc switch. But the intresting part is that, diseqc works good with ku band and not with c band.
    Thanks everybody for the help
    Bjv
  1. Is anybody receiving TPS channels with no problems
    By azaymick in forum RDI - English
    Last Post: 15th August 2006, 06:57
  2. Receiving Hispasat from Egypt?
    By Senab in forum RDI - English
    Last Post: 31st May 2006, 18:03
  3. Anybody receiving Eurobird 28 in Pak or Middle East
    By wiseguy4u in forum RDI - English
    Last Post: 22nd October 2005, 01:12
  4. Is any body receiving Star.........
    By khurram in forum RDI - English
    Last Post: 3rd October 2005, 23:28
  5. Those receiving Eutelsat W3A...
    By fundom in forum RDI - English
    Last Post: 3rd August 2005, 10:06
