    alaakat
    Default plz help me I will be crazy
    can some body help me how to enter aes tps keys in 16 I can only enter 8 bytes plz help
    Italy
    Your receiver please?
    Semel in anno, licet insanire.
    Default Re: plz help me I will be crazy
    Quote Originally Posted by alaakat
    If you have a key like this example
    01: 11 22 33 44 55 66 77 88 99 00 11 22 33 44 55 66
    you can split it in two like this;
    11: 99 00 11 22 33 44 55 66
    See how you have added the NEW 11: line.
    Works in most set top boxes so good luck.
    After posting this I see there is another thread at
    http://www.********.com/f2/viewtopic.php?t=56532
    which may help you out as well.
    still waiting for your receiver
    ssss
    Behind Thor
    Quote Originally Posted by kuband
    Most receivers do not have this capability as you have to update the soft ware when the key changes.
    Pity as it would be easy to just change the key as before but soft people do not allow it with most boxes for some reason
