    Default How to ad key in to Xsat 410 ??? HELP
    Who can tell me how to add the CAS key in to Xsat 410
    Thank you
    SATELLITE GURU Expert
    Default Re: How to ad key in to Xsat 410 ??? HELP
    Quote Originally Posted by mlccs
    Thank you
    You cannot. You need to use a card.
    Program Silvercard with BBAIO files and then you can use the remote to update keys.
    Refer to readme.txt for working satellite and channels.
    aleenamadee
    when ur receicer is on and flugged to ur tv set, just dial 8282 with ur xsat remote control. It will display to u on ur tv the edit key menu, scroll to the desired area u want to insert key..........
    to aleenamadee
    Could you tell us more detail? Which type of firmware that can we do that? or any!
    We do that when the reciver is ON or in standby mode?
    Thank you.
    Sep 2004
    UAE
    hi to all,
    What's new on @Mg85f XSAT 410 2.0.8 EMU
    --> IMPORTANT <--
    / Flash again Firmware + Favo /
    AES by remote control (based on 2.0.5 version)
    Algo N2 D+ added
    Known bug :
    Fast reset on d+ if pmt not checked, ecm can crash on some channel
    (Difficult to fix, seems to be an official bug firmware since 2 realease)
    for remember
    Description parental lock :
    --> 1111 emu run with osd
    --> 2222 emu run without osd
    --> 3333 emu off, jmp original mode
    Include Algo Via1
    Include Algo Via2
    Include Algo Tp*crypt 1
    Include Algo Tp*crypt 2
    Include Algo Mediaguard 2
    Include Algo Nagra 2 Carmageddon
    / 015000, 0094, 007c
    4101,0101 D+ N2, 0065 cyfra (without nano fix)
    Always use last realease of firmware if you want to enjoy
    new fix .. watch out for next version
    Special thanks go out to the ppl who made this possible:
    Arrobase, Jpacino, Wapopetzo, Koala2048, Axis
    Special Greats to some guys who made fantastic support on @mg's firm
    Lulu Berlu, DDSat Mods & Members .....
    Modified for D+ .Now working again
    by Tojo
    Note: To the owners of Xsat410 prodused after april 2005 . I suggest
    to put parental code before loading new software to -----3333
    to prevent the set to block on " INIT ".So you can use your own FAV channels.
    Activate EMU with ------1111
    To prevent blocking before turn off the set put patental code back to
    ------3333
    With this maner the set will start initialing normaly !
    this is taken from satkey.org
    Senior Member Teacher
    May 2005
    On The Move
    Quote Originally Posted by xratedchannel
    @xratedchannel
    Very Intresting Information... I have never seen a X-SAT working with
    keys,Could it possible with X-SAT cloned receiver like made from
    china.. if yes what is the proceeder...?
    Regards
    ART IS TO COMMUNICATE.....
  1. Can someone help me about Xsat 410
    By adaroubala in forum RDI - English
    Last Post: 25th July 2005, 20:23
  2. about xsat 410
    By dioudiou1 in forum SD Receivers
    Last Post: 1st December 2004, 18:59
