    Jed, KSA
    Default How to read teletext on humax 5400
    Dear all,
    Does any one knows how to read teletext on humax 5400. Is there any software available or it is not possible to read teletext. Most of the receivers have this facilities.
    Thanks
    Humax has only subtitle facility (yellow button on remote control), if you want the complete teletext you'll have to use the TV's own teletext.
    May 2004
    multumesc Kroky my friend for corretion
    ALIBE
    It is possible to read Teletext as follows:
    1) Make sure that you have a co-axial (aerial) connection from your Humax to your TV.
    2) Tune in any appropriate channel on your TV to receive the transmissions from your Humax to your TV via the aerial.
    3) Select a satellite channel that carries teletext.
    4) Use your Teletext buttons on your TELEVISION REMOTE CONTROL
    Hey Presto. You should be able to read the Teletext transmissions.
    Note: It will not work through a Scart lead connection.
    Quote Originally Posted by ALIBE
    It's not true, teletext is working (on TV, of course) on all 3 outputs: TV Scart, VCR Scart and RF out!
    May be your TV is not working with AV input!
    ALIBE
    Neither of my TV's will cope with Teletext through the AV connections.
    It is a known fault that many (but not all) TV's have the same problem. This means that even if a Digital Receiver like the Humax has the ability to transmit the Teletext part of the signal through the AV outputs, it cannot be received. This can sometimes be resolved by cutting / disabling certain connections within the Scart connector.
    The following site has some interesting information about Scart connections and their shortfalls:
    http://www.satcure.co.uk/tech/scarts2.htm
    However, if you are experiencing a lack of Teletext, my suggested solution (i.e. looping your aerial through your Humax) should work.
    This should give a solution to Afridij.
    I accept that perhaps I should have originally said "On many TV's it will not work through a Scart lead connection".
    Default MINE WORKS
    MY PHILPS TV CRT 29 AND 21 BOTH WORK
    NO PROBLEM HERE
    Jed, KSA
    thanks for reply but my TV does not have teletext facility.
    Thanks
  1. Humax 5400 Plus
    By Kroky in forum RDI - Satelit
    Last Post: 14th November 2006, 22:25
  2. help my humax 5400
    By giolgau in forum SD Receivers
    Last Post: 17th February 2006, 13:18
  3. About Humax 5400
    By kabir2005 in forum RDI - English
    Last Post: 13th June 2005, 14:19
  4. ? 4 HUMAX 5400
    By bamisto2 in forum RDI - English
    Last Post: 13th May 2005, 00:59
  5. humax 5400
    By Junghi in forum SD Receivers
    Last Post: 4th January 2005, 11:26
