    Apr 2004
    Default HELP--DREAMBOX 7000S-CARTELA MAX
    SUNT IN POSESIA UNUI DREAMBOX DM 7000S...AM IN FLASH O IMAGINE GEMINI 2.60.....,AM PUS MANUAL(DUPA CARE AM DAT JOS DIRECT DE PE NET CU DREM-UL) EMULATOARELE...CAMD.3.832, ultimul NEWCAMD,SCAM 2.5.... NU MERGE NIMIC.....MA DISPERA...AM PUS SI ULTIMELE CHEI PT FIECARE DIN ELE....SI DEGEABA....
    va rog frumos daca ma poate ajuta cineva.......as ramine dator...cu o masa plina cu bere....stau in casa de vreo 4 zile si nu-mi dau seama unde gresesc ...sau ce trebuie sa fac...cred totusi ca poate trebuie sa configurez emulatorul----cartela am probat-o ...e ok----
    VA MULTUMESC MULT
    MYKY
    May 2004
    tb sa dai jos in cam config>camd3 cfg si merge.
    Apr 2004
    pot sa-l dau jos de pe net?...te intreb pt ca nu stiu de unde sa-l iau...
    scuza-ma..dar te superi....poate incerci tu sa mi-l trimiti in pm sau mail....TE ROG MULT
    MERSII MULT
    MYKY
    _...._ Expert
    Sep 2003
    Queen Maud Land
    in meniu la addons, ai pt download si optiunea cam config.
    May 2004
    daca ai dreamu"conectat la net>buton albastru>addons>download and install>cam-config>camd3 config.reboot now si merge.
    Sau manual intri in meniul Blue Panel-Addons-Manual install si dai Ok sa configurezi pe rand toate camurile pe care zici ti le-ai bagat. Vezi sa ai si toate drepturile date ca sa poata vedea keyle.
    Antena 1,8m/Montura polara/Lnb Invacom quad 0,3db/Actuator 12"/Pozitioner diseq Moteck/DB 7020s/DigiTv
    Apr 2004
    va multumesc mult...am reusit
  1. dreambox 7000s
    By danu in forum DREAMBOX
    Last Post: 7th April 2006, 21:44
  2. HELP--DREAMBOX 7000S--KEY
    By irlandezu in forum DREAMBOX
    Last Post: 10th September 2005, 10:43
  3. dreambox 7000s
    By BIHOREANUL in forum Shop
    Last Post: 2nd August 2005, 14:26
  4. Dreambox 7000s!!!
    By arhanghelxxl in forum Shop
    Last Post: 2nd August 2005, 14:22
