Results 1 to 14 of 14
    Iasi / SE UK
    Default digi 1880 oscam settings
    Salutare , am un card digi 1880 in Enigma2 si nu vrea sa deschida nici un program .
    Am avut un 1802 si a mers foarte bine . Dar asta nu deschide deloc .
    Device: /dev/sci0
    Group: 1
    Loadbalance weight: 100
    Caid: 1880
    Ident: 1880:002011,002111,002113
    ECM not found limit: 5
    ECM whitelist: 1880:89
    Emmcache: 1,3,2
    I-mi scrie Card OK cu 3 entitlements pana in 5.2.2017 .
    2016/10/15 15:25:38 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:38 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:39 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:39 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:39 592780 r Digi [nagra] dvbapi emmtype=global, len=139, idx=27, cnt=1: written (606 ms)
    2016/10/15 15:25:40 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:40 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:41 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:41 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:42 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:42 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:43 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:43 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:43 592780 r Digi [nagra] dvbapi emmtype=global, len=139, idx=28, cnt=1: written (611 ms)
    2016/10/15 15:25:44 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:44 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:45 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:45 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:46 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:46 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:47 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:47 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:48 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:48 592780 r Digi [nagra] dvbapi emmtype=global, len=139, idx=29, cnt=1: written (613 ms)
    2016/10/15 15:25:48 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:49 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    2016/10/15 15:25:49 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:50 5AEFC8 c [DVBAPI] Demuxer #0 no suitable readers found that can be used for decoding!
    2016/10/15 15:25:50 5AEFC8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
    Save Log
    Poate sa ma ajute cineva sa-l fac sa mearga ?
    DM-800 clona SIM201 bl84 , Cristor Atlas 100HD
    undeva de la Sibiu
    [reader]
    label = digitv
    protocol = mouse
    device = /dev/ttyUSB1
    caid = 1880
    boxkey =
    rsakey =
    fix07 = 0
    readtiers = 0
    ecmwhitelist = 89
    detect = cd
    mhz = 600
    cardmhz = 368
    ident = 1880:000000,002011,002111
    group = 2
    emmcache = 1,1,2,0
    lb_weight = 300
    cccreshare = 1
    auprovid = 002011
    Iasi / SE UK
    Multumesc @bartusch , era la ident , am schimbat si a mers .
    undeva de la Sibiu
    ma bucur daca te-a ajutat
    Dec 2011
    Salut Bartusch, poti sa ma ajuti si pe mine sa configurez o carte digi pe un receiver Mutant hd51. O am acum in Dreambox DM800se si merge foarte bine dar receiverul nou nu mai suporta Cccam.
    undeva de la Sibiu
    suporta oscam?
    Dec 2011
    da suporta. eu nu ma pricep prea bine cu setarile. este ca dreambox DM900 UHD 4k.
    undeva de la Sibiu
    setarile de sus ar trebui sa mearga. Daca folosesti cartea in readerul intern atunci...
    [reader]
    label = digitv
    protocol = internal
    device = /dev/sci0
    caid = 1880
    boxkey =
    rsakey =
    fix07 = 0
    readtiers = 0
    ecmwhitelist = 89
    detect = cd
    mhz = 500
    cardmhz = 368
    group = 2
    emmcache = 1,1,2,0
    lb_weight = 300
    cccreshare = 1
    auprovid = 002011
    Dec 2011
    merci. Cum pot sa instalez oscam svn pe receiver, ca nu am habar si nu ma pricep si nici timp sa citesc nu am din pacate.
    Mar 2013
    C-ta
    Depinde ce img folosesti pe aparat , asta ca sa nu incurci locatiile , le poti transfera prin DCC , Filezilla ....etc
    Fisierul binar ( oscam ) de regula se pune in usr > bin , cu atrb 755
    Scriptul depinde de ce img folosesti , il transferi si-i dai atrb 755
    Fisierele de configurare ( config ) in etc > tuxbox sau in usr > keys ....depinde ce " spune " scriptul , avuta grija la atributele fiecaruia .
    Dupa care dai un restart la aparat , mergi pe butonul albastru de la telecomanda ....si intuitiv vezi de unde poti da Start / Restart emu
    P.S. Te-as indruma sa instalezi oscam din TSpanel ( fisier ipk care se instaleaza in rec . ) dupa care vezi locatiile , salvezi bin si script , repuii img de la zero , apoi transferi ce ai salvat in rec ...
    succeeesssss !
    Dec 2011
    Folosesc img openATV dar numai atat stiu sa fac sa instalez img pe receptor, din pacate. Nu am habar ce inseamna "binar", "script" imi pare rau.
    Aug 2003
    Karlsruhe- Arad
    atita timp trebuie sa fie biti 1962, cel putin lucrurile elementare sa se stie
    pune odata pe google- openatv 6.0 softcam feed ipk download
    si o sa gasesti o gramada si destule HowTo, iti instal oscamul din feed- si trebuie doar sa il faci pe lucrurile tale
    Mar 2013
    C-ta
    Ok nu este problema "biti1962 " , toti au trecut prin etapa asta , cu vointa , timp si rabdare o sa apara reusitele
    , metode sunt multe de rezolvare , trebuie cat de cat sa te documentezi .
    Dec 2011
    multumesc tuturor care si-au facut timp si pentru mine. Am rezolvat problema, multumesc.
