Results 1 to 15 of 28
    Default Problem on setting up BeSat eM Bx
    Hi I have BeSat eM Bx and I'm having problems setting this up in our house I've alredy connect things out but the signal quality stays in 78% no matter where i point it:
    I am sorry please take note that this is just my first time setting up sattelite.
    Questions are the ff:
    1. Do i have to point the dish to a very specific area
    2. Will there be a problem if i will start searching for channels with this signal quality
    3. Does it have to be in an open area?
    4. What are the do's and don'ts?
    Thank you very much btw im from philippines
    Teach me how to dream!
    Default SETTING UP METABOX
    KILOBYTES,
    YES YOU HAVE TO POINT YOUR DISH TO SPECIFIC AREA, AZIMUTH 118.37 , DISH ELEVATION IS 56.5 , LNB TILT 58.37 OR GO TO www.satlex.de/calculator . ussualy the metabox always giving signal quality and streng in yellow color , if it is yellow color still it is bad signal when it becomes green it means it good signal.so even it gives 78% but yellow color still it is a bad signal.
    @ snowite
    thanx very much amm one more thing po.
    here's what i can see in the TV.
    Sattelite = Unused 0.0E
    Diseqc = disable
    0/22khz Control = off
    Posiotioner = off
    Antenna Setup
    Transponder
    Search
    Signal level = 20% - 69% - 70% -79% then back to 20%.. all yellow
    Signal quality = constant at 78% (yellow)
    may i know what is this satellite unused 0.0e?
    I just want to reconfigure some of the stuffs in the system im just curiuos that if i mess with something will it lead to more problem?
    go to this site for referrence: http://www.dream.com.ph/support/supp...l.asp?npage=14
    also make sure that you are tuned to a specific transponder 12301H SR 25600 and adjust your lnb and dish according to the guides above. if you cannot find the agila2 list on your satellite data, just use ANY satellite and input the frequency manually. from what you see on your TV, select transponder and input the freqs as suggested.
    Sa bubong
    Transponders to manually enter for Agila 2 Ku Band
    You can enter these under an "unused" satellite if you dont have Agila 2 in your list.
    Go to "add transponder", and enter these figures one by one.
    You will be adding 6 transponders and each transponder requires the 3 entries listed below.
    12301 Hor 25600
    12541 Hor 25600
    12581 Hor 25600
    12661 Hor 25600
    12541 Ver 14000
    12500 Hor 30000
    Also check under your lnb configuration.
    Select standard lnb or universal , whatever you have.
    Polarity of lnb should be set to auto or vertical or horizontal, whatever works for you. Mine is Vertical or auto.
    Try and line up your dish, details given above.
    Signal and Quality should go green when lined up with satellite.
    Check your polarity of lnb if no green (took me almost a week to figure that one first time....duh)
    After that go to "search" or "scan", choose the search all option.
    You should get 69 tv channels and 14 radio.
    asia
    Quote Originally Posted by kilobytes
    @ snowite
    Diseqc = disable
    Posiotioner = off
    Antenna Setup
    Transponder
    Search
    you are almost there in shooting the bird. all you have to do is more patience. lnb position shld be bet 7-8 oclock...dish elevation should be bet 55-60 degrees... dish should be facing 120 deg east.. look if there is any obstructions..
    unused0.0.e is a configured satellite. the one who set up your stb favorite sat is unused... like me hehehhee...
    another thing the tp should be 12541 h 25600 ... get the highest signal of it so that all other tps have a good signal too.....
    lakaypogi
    Bu Ru Hu Xue, Yan De Hu Ze
    Ton Zhou Gon Ji
    @kevo,
    consider yourself lucky if you got it on a week's time. when i was a newbie-wannabe-trying-hard, it took me almost a month of going up to the roof with the tv set, extension cords, STB and a bottle of water to shoot for Atlantic Bird3 here in kuwait, sometimes under the searing heat of the dessert sun (im not that good with brains and thinking at times). we all could charge it to experience though. once you get the hang of it, you'll be tuning dishes even with your eyes closed, lol.
    @kilobytes,
    patience mate, you already have the essentials as posted above. all you need is a steady hand and a very patient mood. don't go up the roof when you know your favorite kilawin and lambanog are waiting downstairs with your closest friends. also try moving your dish a bit at a time since you must probably be using a 60-90cm dish only. good luck and do tell us here if there is cause for celebration, k? i just might sacrifice my pet dog "tagpi" to make pulutan, just in case.
    KSA
    need help plz anyone...
    my friend also has a besat embx bought from here in saudi but now installed in the phils but not dream au, he has never tried upgrading a receiver software before, can anybody from the phils be kind enough to give instruction to him thru phone (of course he'll pay for the call) just pm me a contact #...salamat ng marami...
    tnx to all for your help...
    Thank you for all your input guys, this is my second day of setting up my STB goodluck to me and i hope i can shoot that bird this time...
    Sa bubong
    If possible, try and set your tv up outside where you can see it from the roof. Will save you a lot of headache/sunburn.
    The last time I installed a dish, I took a hint from someone here on he forum (maybe even Boknoy )
    I took a small 5 inch lcd tv borrowed from a friend, together with my stb and set it all up on the roof with a long power extension to plug my box into.
    The whole thing took less than 30 mins this way. A BIG improvement from the first time I did it. (Im still darker down one side of my body!)
    A compass from national bookstore will also help you out in finding 120 degrees for the first time. Good luck.
    asia
    Quote Originally Posted by kapmilya
    chek ur pm
    Ton Zhou Gon Ji
    nyahahaa my second day still no luck of finding that bird any idea what am i doing wrong nyahaha thanx a lot guys...
    hay kakapagod hehe question lang po ito kasi spec ng LNB ko pede kaya ito:
    UNIVERSAL SINGLE LNBF
    SRT L738
    Input: 10.7 - 12.75Ghz
    Output: 950 - 2150Mhz
    Noise figure:0.3dB
    yes, just indicate on your satellite setup universal lnb.
    I got the bird and its free now THANX TO ALL OF YOU
    snowite
    boknoy_ph (again)
    kevo
    lakaypogi
    kapmilya (for upping the thread hehe)
    You teach me how to dream now im sharing it with you
  1. Avatar setting
    By zulfiqarjpj in forum RDI - English
    Last Post: 8th May 2006, 20:17
  2. Problem BESAT 5400 & HUMANACE Skyci2003 need help
    By wangyutan in forum RDI - English
    Last Post: 25th April 2006, 12:45
  3. Besat 2400 super gold problem
    By wbvilla in forum RDI - English
    Last Post: 28th November 2005, 05:37
  4. humax setting
    By badboy in forum SD Receivers
    Last Post: 5th August 2004, 07:28
