    Default how to insert long t*s's codes in f*n card
    Hi, sorry for my bad english, i don't remember it very well. I've a problem: there are a lot of character(code) long for t*s bat i nedd to know the system to put them in f*n card.
    Can you help me?
    Thanks and happy new year
    May 2004
    hi,
    to put AES keys in your funcard you will need a tool called VIA 1&2 Editor by Bassem. for more info on how to do it and to download the program follow this link How to add aes key to your old file extee.hex
    ciao!
    Trelalela Expert
    Liechtenstein
    Default @Saed
    @Saed did you check the ink before Replay ?
    PLZ Do . Thanx !
    Best Regards
    Prospector/PapaDan
    May 2004
    @PapaDan
    thx for your concern, i did checked the link and it worked with me, actually it requires registeration. i could not find much better tutorial else this link so i put it here.
    multumesc!
    Default satellite007
    Thx very much, saed, i'll find the file in the site, i'll hope di make the work soon. I'll tell you the result.
    Bye
  1. Long wire antenae help please
    By wonkydonky in forum RDI - English
    Last Post: 3rd April 2006, 13:57
  2. Strong 6xxx-how long?
    By veskop in forum SD Receivers
    Last Post: 21st September 2005, 12:05
  3. how to insert pic
    By deutsch in forum RDI - English
    Last Post: 5th January 1970, 08:05
