Results 1 to 3 of 3
    Senior Member Teacher
    May 2005
    On The Move
    Default DISEQC SWITCH PROBLEM
    DEAR FRIENDS,
    I am using 4 satellites (4 SINGAL POL LNBS) which is connected to THREE
    diffrent DISEQC switches through splitters for three receivers.
    Others receivers working perfectly with same DISEQC SWITCHES one of
    them is ASTRX but i have problem with HUMAX which i am getting only
    signals from only two lnbs.
    when i was configuring the antenna setting & manual search i got signal
    from all four lnbs..
    but when i tried to change channels from the list i was only getting two
    satellite signal but other two were showing bad signals.
    I am using TOH-HOT 5.3 firmware and i have experienced many time
    HUMAX hanged up...
    i have used two diffrent DISEQC SWITCHES 1.0 & 2.0 but same problem
    exist...
    could it possible to add the satellite with frequencies in humax through
    PC...becuse i cannot find asiasat,pas 10,insat 2e..etc...in antennas
    setting...
    can anyone explain what's going wrong...
    Regards
    ART IS TO COMMUNICATE.....
    Lahore
    You have been replied
    Fte Max 100S
    Humax IRCI-5400z
    May 2005
    On The Move
    @masood
    Regards
  1. DiSEqC switch for 8 LNB’s...
    By bigboss in forum RDI - English
    Last Post: 31st July 2006, 08:46
  2. SWITCH DISEQC V2.0 2/1 TRIPLE DRAGON...
    By BABANOVAC1980 in forum DREAMBOX
    Last Post: 15th July 2006, 04:23
  3. 4 in 2 out DiSEqC switch
    By Anver in forum RDI - English
    Last Post: 20th May 2006, 18:23
  4. DISEQC SWITCH PROBLEM
    Last Post: 7th January 2006, 17:54
  5. Diseqc Switch
    By flipper in forum Placi DVB
    Last Post: 4th October 2005, 10:25
