    Mi se rupe Expert
    Default probleme, probleme cu VU+ duo2 si skydeS02 karte
    oameni buni, am trecut pe Vu+dar problemele nu dispar niciodatä.
    Vu+ duo2 cu VTI 8.0.0 si oscam 10646, nu vrea nici de-al draq sä-mi deschidä kanalele SD de pe kartela SkydeS02.
    dacä imi aduc bine aminte, cind am cumpärat Vu si l-am configurat, mergeau.
    acum merg numai kanalele HD, deci 1833.
    oscam.conf aratä asa
    # oscam.conf generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r10646
    # Read more: http://www.streamboard.tv/svn/oscam/...oscam.conf.txt
    [global]
    disablelog = 1
    serverip = 192.168.0.13
    logfile = stdout
    netprio = 1
    nice = -1
    maxlogsize = 500
    waitforcards_extra_delay = 300
    preferlocalcards = 2
    lb_mode = 1
    lb_save = 100
    lb_nbest_readers = 2
    lb_nfb_readers = 2
    lb_auto_betatunnel_mode = 1
    lb_auto_betatunnel_prefer_beta= 1
    lb_noproviderforcaid = 09C4:FFFF
    double_check_caid = 1702,1833,1801
    [anticasc]
    enabled = 1
    penalty = 3
    [cache]
    delay = 100
    max_time = 9
    wait_time = 1702:950,1833:550
    csp_allow_request = 0
    cwcycle_check_enable = 1
    cwcycle_check_caid = 098C,09C4,09C7
    cwcycle_onbad = 0
    cwcycle_dropold = 0
    [cccam]
    port = 12000
    nodeid = FFF6479C10681584
    version = 2.3.0
    reshare = 3
    reshare_mode = 0
    ignorereshare = 1
    forward_origin_card = 1
    stealth = 1
    [dvbapi]
    enabled = 1
    au = 1
    delayer = 100
    user = local
    boxtype = dreambox
    [monitor]
    port = xxxxx
    monlevel = 4
    [webif]
    httpport = xxxxx
    httpuser = eu
    httppwd = toteu
    httphelplang = de
    httpallowed = 127.0.0.1,178.165.132.57,192.168.0.0-192.168.255.255
    httpdyndns = a me
    oscam.reader
    # oscam.server generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r10646
    # Read more: http://www.streamboard.tv/svn/oscam/...cam.server.txt
    [reader]
    label = skydeS02
    protocol = internal
    device = /dev/sci0
    lb_whitelist_services = skywelt,skywelthd,skyfilm,skyfilmhd,sky3d,skyfußba llbundesliga,skyfußballbundesligahd,skysport,skysp orthd,skyselecthd,skyerotik,skyorf,skyorf
    autospeed = 0
    cacheex_allow_filter = 0
    caid = 1702,1833
    boxkey = 1122334455667788
    force_****** = 1
    ecmheaderwhitelist = 1702:807090C7000000011010008712078400,817090C70000 00011010008713078400;1833:803086078400,81308607840 0;1830:80308F078D,81308F078D;1722:807051C900000001 1010004812074511,817051C9000000011010004813074511, 807090C9000000011010008712078400,817090C9000000011 010008713078400,807090C7000000011010008712078400,8 17090C7000000011010008713078400;1834:803086078400, 813086078400;1838:80308F078D,81308F078D;1831:80304 7074511038600,813047074511038600;1805:80308ED387,8 1308ED387;183D:80308ED387,81308ED387;0604:807041,8 07049,807061,817041,817049,817061;1810:80308607840 0,813086078400;09CD:8070B4000001,8170B4000001;0100 @00006A:813061006A00075C00,803061006A00075C00,8000 61006A0000,810061006A0000;[email protected]:817032009003 043808DE0451,807032009003043808DE0451,817032009003 043808DE0451,807032009003043808DE0451,817037009003 043808DE0451,807037009003043808DE0451,817045009003 043808E20342,807045009003043808E20342,81704A009003 043808E20342,80704A009003043808E20342,81703B009003 043808E20342,80703B009003043808E20342;[email protected]: 817027009003023808,807027009003023808;[email protected]: 80702D009003050808DE045058,81702D009003050808DE045 058;[email protected]:81702D009003040818DE045137,80702D0 09003040818DE045137;[email protected]:80712701,80713F01, 81712701,81713F
    detect = cd
    mhz = 450
    cardmhz = 2700
    ident = 1702:000000;1833:000000
    group = 1
    emmcache = 1,1,2,0
    saveemm-g = 1
    oscam.user
    # oscam.user generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r10646
    # Read more: http://www.streamboard.tv/svn/oscam/...oscam.user.txt
    [account]
    user = local
    caid = 1702,1833,1802,1880,0B02,1830,1843,0B00,0500,4ABF, 0100,1810
    uniq = 3
    monlevel = 4
    suppresscmd08 = 1
    au = skydeS02
    betatunnel = 1833.FFFF:1702
    group = 1,2,3,4
    cccmaxhops = 5
    cccreshare = 1
    cccignorereshare = 1
    toti partenerii mei de SH väd kanalele SD.
    in celälat box din dormitor merg toate kanalele SD si HD.
    am bägat si kartela in celälalt box din dormitor , pe care am cccam si merge absolut tot.
    mä gindeam cä nu si-a fäcut update, dar e la zi.
    dati-mi ceva idei cä de 3 zile tot schimb la confuri de m-am plictisit si eu si tot nu-i dau de cap.
    mä gindeam sä nu fie de la imagine VTI, ce ziceti?
    Inimos din cale afara Expert
    in my own mind
    eu am linie de la tine... de asta cade mereu? ce eu ii injuram pe astia cu netu. incearca ultimul BH...
    Daca tot ai VTI 8.0 de ce nu iti configurezi oscam-ul cu Oscam Butler de la ei de pe server ?!? Si atunci esti sigur ca este configurat bine , pe urma mai adaugi numai service pt. reader-ul respectiv si gata( in cazul ca mai legi si CCCam de el ) . Testezi cu minimum de config. iar pe urma adaugi ce mai vrei . Si eu folosesc VTI 8.0 + oscam pt. cartelele 098c si 0d95 , configurat cu Butler si merge bine .
    Mi se rupe Expert
    @sky
    sorry cä te-am fäcut sä-i injuri pe äia cu netu (oricum meritä injurati)
    @FLAVIUS
    am rezolvat problema.
    am vrut sä fac singur conf, sä nu folosesc un program ajutätor, ca sä si stiu de ce merge si de ce nu.
    problema o fost la Config-DVB-Api, la Request Mode am avut 0=try all possible CAIDs one by one , trebuia 1=try all CAIDs simultaneously.
    merge
    mersi cä te-ai implicat
