    Ireland
    Default problema de programare x-cam cu cas2, help please!!
    am o problema-am incercat sa programez un x-cam cu cas 2 dupa instructiunile de la duolabs, dummy cardul am bagat in cam si camul in humax. Receiverul recunoaste versiunea camului, deschid programul de programare cas-inainte sa fie bagat camul in receiver im apare x-cam, dar cum bag camul in receiver se face umbra icoana de x-cam pe calculator. dau erase x-cam si numai apare starting connection--dar nimic. am incercat direct sa programez fara sa-l mai sterg, dar dupa citeva secunde apare connection failed.care poate sa fie problema ce nu fac bime(block 2 e la settings)).Help me please!
    Ireland
    Da chiar nimeni nu stie
    Ro
    Default X CAM
    Pune rec pe un program FTA introdu cam-ul in rec, conecteaza calculatorul la cam prin serial si dummy card, intra in meniul camului la serial update, cu CIW X CAM loader 1.5 incarci noul soft (block 02), dupa restartarea rec incarci si noul softcam (block 14) dupa care restartezi receptorul din nou. Bafta!
    Ireland
    ce, serial? cas2 se conecteaza cu usb la calculator.ai nevoie de add on ca sa programezi x-cam
    Belgica,Antwerpen
    Exact...iti trebuie ADD ON +panglica + dummycard,ca sa scrii Xcam-ul http://www.cellularcenter.it/duolabs...as2add-eng.pdf si dute la pag.21.
    Ireland
    mercy, am sa-l incerc
    http://www.duolabs.com/down-cas3.htm
    Manual in linba romana te ajuta si la CAS2
  1. CAS2
    By armandino in forum Shop
    Last Post: 3rd October 2006, 22:22
  2. Ptr. cei ce au CAS2 sau 3
    By liniuta in forum RDI - Satelit
    Last Post: 25th November 2005, 04:55
  3. Cumpar Add-on Cas2!
    By dirtyfreddie13 in forum Shop
    Last Post: 8th September 2005, 21:28
  4. new cas studio 6.4 cas2 & 3
    By gogi in forum RDI - Satelit
    Last Post: 31st August 2005, 18:45
