Page 7 of 8 FirstFirst ... 5678 LastLast
Results 91 to 105 of 112
Thread: Vu+ Zero
  1. #91
    May 2014
    undeva pe pamant
    Pe digi cablu merge pachetul de baza. Nu te astepta la mai mult pentru ca vu-urile nu stiu CI+ . CI+ stie televizoarele moderne. Folosesc vu+ pe multimedia . DLNA, xbmc ,kodi.
  2. #92
    Oct 2014
    pune oscam emu si o sa mearga
  3. #93
    Aug 2007
    Bucharest
    Ce nu inteleg eu la acest tuner tv usb dvb-t rtl 2832u+Rt820t este cum il conectezi la cablu. Ca mufa cu care vine se poate lega doar la antena terestra cu care se livreaza.
    [email protected] HD51,[email protected] HD2400, T90 4w-42e, offset 1,5-1w/5w/4,8e, offset 1,2 HH 30w-56e
  4. #94
    May 2014
    undeva pe pamant
    Si cate mufe sunt in comert ...
  5. #95
    Aug 2007
    Bucharest
    și cine e meseriașul care poate sa facă asta? ca as avea nevoie de priceperea lui...
  6. #96
    Aug 2007
    Bucharest
    Sau mult mai simplu se rezolva asa:
    [IMG]image hosting 15mb[/IMG]
  7. #97
    May 2010
    Default openpli
    am luat openpli ultima versiune si nu mai apare oscam nu stiti de ce?
  8. #98
    Default Black Hole 3.0.3 Vu+ Zero
    Merry Christmas from the Black Hole Team
    Black Hole 3.0.3
    What is new ?
    - Add Support for Uno4K and Ultimo4K
    - Update default skin MX HQ10 for extra tuners
    - Update skin api
    - Update OpenMultiboot
    INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
    This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
    Download EPG from any channel
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to plnick for help obtaining missing Ultimo4K files.
    Thanks to Pedro_Newbie for Backup script.
    Thanks to [email protected] for the file satellites.xml.
    Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
    DISCLAIMER
    LICENSE (TERM OF USE)
    BlackHole-3.0.3-vuzero_usb_release_20161224_d3f1586.zip
    File size:99.6 MB
  9. #99
    Oct 2014
    Imi poate face cineva un test ... cu cablu scos din tuner, ale voastre arata semnal ?
    1W-13E-16E-19.2E
    Offset Triax (Alu.) 1.00
    Offset Multifeed Emme Esse (Alu.) 1.15
    VU+ Ultimo 4K/VU+ Solo SE V2/ VU+ Zero/ GM Triplex /Amiko Spiel/
    Digi Cablu /Focussat /SRTV
  10. #100
    Jun 2006
    popescu bogdan PE FACEBOOK
    ? whattttttt?
  11. #101
    Oct 2014
    e nou
    adica asa
    l-am setat tot si trebuie sa-l trimit acasa. doar ca mi-a sarit asta in ochi :
    LE : Arata semnal, fara cablu conectat la satelit, in configuratia simple diseqc a/b/c/d. E normal sau are defect la tuner?
    1W-13E-16E-19.2E
  12. #102
    Oct 2014
    schimband canalele, arata valori de semnal doar pe transponderele DVB-S2 indiferent de satelitul din diseqc .pe cele dvb-s arata doar AGC si cateva sclipiri la SNR
    1W-13E-16E-19.2E
  13. #103
    Oct 2014
    Bugul este confirmat pe un frate al lui ... acum asteptam raspunsul oficial de la VU+
    Many thanks for your report and it has been recorded.
    Our development team will review this report and contact you via e-mail if any follow up information is required.
    Your valued bug report will help to us to investigate this issue and we would try to fix in a short time.
    Best Regards.,
    Vu+ Team
    tnx Anonimul pentru test
    1W-13E-16E-19.2E
  14. #104
    Aug 2004
    United States of Terra
    Cu respect. Oricnd.
    http://www.youtube.com/watch?v=92QzUojy0bM / Richard Marx - Right Here Waiting. / ,,Cel care nu a escaladat un munte, nu cunoaste inaltimea..cerului !'' / Radio Jemne Melodie, Radio Country, Radio Istok Bor, Vlajna Radio, Radio Valea Moravei, Kiss Plus Radio, Radio Energy, Magic FM, Star FM. / ,,Iubirea este unicul sport care nu moare cand se stinge lumina, dimpotriva ...se intensifica!'' / ,,Daca ai sufletul mare, multi..ti-l calca in picioare... ! ''/ http://www.youtube.com/watch?v=LIgrLTZwjos / ENDLESS LOVE .. Mariah Carey & Luther Vandros / ,,Frumusetea sufletului se masoara-n calitatea faptelor nu in cantitatea ...vorbelor !'' / ,,Romania, nu e
    doar pamantul pe care pasim ci si cerul de deasupra noastra.'' / ,,Bunul Dumnezeu nu ne cere sa reusim ci vrea doar sa incercam din tot sufletul.'' Maica Tereza de Calcutta. / ,,Cand viata e blanda cu noi, nu trebuie sa ne intrebam...de ce...'' / http://www.jemnemelodie.sk/ / ,,Mergi inainte iar daca acel ceva sau cineva pe care-l cauti, nu exista inca fii convins(a) ca Bunul Dumnezeu il va crea intradins pentru a-ti rasplati indrazneala !'' / http://www.shoutcast.com/radio/Vlaska.
  15. #105
    Default Black Hole 3.0.3.D Vu+ Zero
    Black Hole 3.0.3.D
    What is new ?
    - Update default skin MX HQ10 to fix font issue's with Ultimo4K
    - Update drivers (solo4k, uno4k, ultimo4k)
    - Update libvugles2
    - Update Satellites.xml, Cables.xml and Terrestrial.xml
    - Update Danish, French, Italian, Lithuanian, Norwegian, Polish, Portuguese and Spanish translations
    - Update epgcache for MHW2
    - Update OpenWebif
    Addons
    Infobar / OSD
    Analog Clock Gui
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    UPnP Client Djmount
    Pcsc Panel
    Tuner Server
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    DISCLAIMER
    BlackHole-3.0.3-vuzero_usb_release_20170127_371b7f5.zip
    File size:101.9 MB
