    Default HIVION 9090X HELP
    i dont know if this is a problem or not,after searching satellite channels with this stb it will store all the channels and i start to watching a channel for example on channel 10,when i change to the next channel and watch it for even more than one hour and off it from the power supply,anytime i on it again it will never start from the last channel i watched,it will always start from the first channel like channel 10 instead of the last channel i watched any solution pls
    ssss
    Default Hivion 9090X
    Clean your STB first, then reload new firmware ver 1126
    that is, should be ok
    besoy
    cellpipe.
    padala ka ng email sa akin . Yung hivion ko ok na yun din ang nangyari sa akin adv n Ird2 sa akin linisin. loader pinadalhanp pati yung dream auto firmware kaso lang yung system ng hivon 9090x is PAL medyo hindi ako nasiyahan mas okey yung Micro-X sana at besat. Pero ang tagal ng firmware lalabas.
    jeddah
    Default hivion9090x
    Sir Besoy anong sinasabi mong PAL system lang yung Hivion,marami na ring gumagamit sa pinas,di mo lang alam siguro kung paano gumamit ng reciever,pati mga walang kwentang tanong pinupost mo pa.
    middle-earth
    @Nhoy,
    puso mo m8, .it's a better way to xplain your unit
    so he has an idea (malay mo sa iyo na mag-invest yan)
    peace,
    besoy
    Default @Nhoy
    Nhoy,
    Bago mo ako husgahan check mo muna yung system mo kung may hivion 9090x. I have it here two units, defferent model. Check muna yung system mo. Bago ka re-reply para hindi ka masupalpal ng hindi kanais nais na sagot, sa halip nakakatulong ka sa mga baguhan nangunguna ka sa KAYABANGAN.
    Medyo malayo na ang narating ko sa communication network bata hindi lang satellite, Kahit sa GSM tayo o Microwave radio dyan tayo hindi mapahiya. Kahit saan mo ako dalhin nakakaintindi ito.
    Yung video out (PAL) niya sa system. As you can see PAL, PAL1, NTSC/PAL..... para ma-confirm mo kung tama ba ang sinabi ko. Well, hindi ako investor ng satellite. Where the same bro working here in saudi arabia. Pero palagay ko lamang ako saiyo ng kunti if you talk about company kung hindi ako nagkakamali. You know what i mean GSM at hindi ako contractor direct hire ako bro kaya hwag masyadong mahangin kung may mali man ako pwede mo naman seguro e-correct..... am I?
    besoy
    Default hivion 9090X
    @Nhoy
    Pwede naman pala e-privite message titirahin pa ako dito sa public furom. Hindi lang hivion ang rcvr ko dito bro.. (Starsat SR-X550D, Micro-X MDR 4500 FTA, Hivion 9090X & Hivion 9090XCI, XSAT 410 (Yung ginamit ko sa TFC 1st version), ART (NAG150) last version Nagra ng TFC pero gawa din ito ng hivion manufacturer, G-box, Beausat 2007, Besat at iba pa. Mahirap naman yung hindi totoo hindi na bali mahaba basta may katotohanan.
    jeddah
    Sir Besoy kung pilipino ka man dapat lahat nang nakikita mong problema ay check mo muna bago ka magpost sa forum,wala namang problema sa system ikaw lang ang may problema,minsan dapat nag-iisip tayo hindi yung umaasa na lang.Sorry Bro,kung may tama ka.
  1. Hivion 9090X help!!!
    By alibaba in forum RDI - English
    Last Post: 7th December 2006, 03:48
  2. hivion 9090x
    By akira_x15 in forum RDI - English
    Last Post: 13th September 2006, 04:49
  3. Hivion 9090x
    By mauricefra in forum RDI - English
    Last Post: 15th August 2006, 17:22
  4. hivion 9090X
    By besoy in forum RDI - English
    Last Post: 2nd January 2006, 08:58
  5. hivion 9090x
    Last Post: 6th December 2005, 01:01
