Vand receptor digital cablu si satelit DM7025 300 MHz MIPS Processor, Livrare Gratuita in Bucuresti
Dreambox DM7025 Original Dream Multimedia a fost folosit aproximativ 2 ani .
Receptorul functioneaza cu operatorii DTH din Romania, Focus si Freesat, precum si cu alti operatorii satelit de afara.
BONUS* Card CF 128Mb - aveti posibilitatea sa faceti Dual Boot, adica sa instalati 2 imagini (firmware) pe receptor.
Receptorul este functional si configurat, nu ramane decat sa-l conectati la antena satelit, cablu digital, tv si internet.
Vizionare Placuta! *Pentru mai multe Detalii accesati "Trimite Mesaj" din partea dreapta a paginii si puteti intreba acolo!
- Tuner DVB Satelit
- Tuner DVB Cablu
- 10/100MBit compatible Ethernet Interface
- Twin-Tuner
- big size OLED display
Accesori:
- Cablu alimentare
- cablu IDE pt conectare hardisc
- CF card pentru extra memory 128MB
Pret 250 Ron fara telecomanda. (optional telecomanda 50 ron)
Poze reale ale receptorului,
Functioneaza perfect!
Ofer suport vanzatorului pt instalare, reinstalare si folosire.
Technical data
Linux open source (most parts under GPL)
DVB Common-Interface Slot
2 x Smartcard-Reader
Integrated Compact Flash Reader (Slot inside the front panel) 10/100 Mbit Ethernet Interface
USB 1.1 Port
Serial V.24/RS232 port
Graphical LC-Display
128 MByte DDR RAM, 32 MByte Flash
Integrated IDE UDMA66 connector
HDD support for all current disk sizes
Plug&Play TWIN Tuner support, Picture-in-Picture Mode (PiP) Support for multiple LNB-Changeover (DiSEqC)
Skinable OSD in many languages
S/P-DIF optical AC-3 port
2 x Scart-Connector, RF Modulator, Video Cinch out
Analog Modem upgrade available
DVB/S-Tuner (pluggable):
Frequency Range 950 - 2150 MHz
Signal Level - 65 dBm - 25 dBm Signal-to-Noise Level 12 dB max. DBS-Tuner Input Connector F-Type female Input Impedance 75 Ohm
AFC +/- 3 MHz
Demodulation Shaped QPSK
Symbolrate 2 - 45 Mbaud/s, SCPC / MCPC
Inner FEC: Rates:1/2, 2/3, 3/4, 5/6, 7/8 (DVB specification) Demultiplexing according to ISO 13818-1
DVB/C-Tuner (pluggable):
Input/Loop through Connector IEC 169-24, Female Frequency Range 50 - 870 MHz
Signal Level Input -20 - 25dBm
Demodulation QAM
Constellation 16, 32, 64, 128 and 256 QAM Input Symbol Rate 7.252 Msps max.
