Results 1 to 2 of 2
    Timisoara
    Default Mini videoproiector LED
    Vand mini videoproiector LED, nou , doar incercat , cu toate accesoriile. Detelii tehnice :
    Model UC28+
    Quantity 1
    Color White + black
    Material ABS
    Type LCD
    Brightness 400 ANSI lumens
    Display Size 30~60 "
    Contrast Ratio 300:1
    Native Resolution 320 x 240
    Maximum Resolution 1920 x 1080
    Aspect Ratio 16:9 / 4:3
    Pixels 576i
    Throw Distance 3~3.8m
    Lens F=125
    Built-in Speakers Yes
    Lamp Type LED bulb
    Lamp Life 20,000 hours
    Input Video Compatibility Digital
    Input Audio Signals 7-sound effect + SRP
    Input Connectors HDMI, 12V DC port, AV, USB, SD card slot, VGA
    Output Connectors Speaker, 3.5mm connector
    Other Connectors HDMI, VGA, IR
    External Memory Supports SD card up to 32GB
    Power Supply 2-Flat-Pin Plug (100~240V)
    Power Consumption 24W
    Other Features Physical resolution: 320 x 240; Supports resolution: 576i; Brightness: 400lm; Color: 16770K; Contrast ratio: 300:1; Audio format: MP3, WMA, AAC etc; Seven kinds of surround sound + SRS; Image format: JPEG, BMP, PNG etc; Support picture zoom, rotate 360 degrees, you can watch full screen; Video format: HDMI / MP4 / RMVB / RM / MKV; Supports English
    Packing List 1 x Projector
    1 x 2-flat-pin plug power adapter (100~240V / 140cm)
    1 x Remote controller (Powered by 2 x AAA, not included)
    1 x AV cable (19cm)
    Pret 350 lei.
    DM800+3 DM500 + server Oscam+3CC ........ 93E-31,5W
    Timisoara
    -----------------UP---------------------
