Results 1 to 6 of 6
    Default Newcamd and wincsc problem
    I m trying to setup a card sharing server to my lan which has 3 pcs (linux cardsharing server and 2 pcs with skystar2)
    For cardsharing server i have a [email protected] runing debian 3.1 with 64MB ram
    Infinity USB Phoenix card reader and a [email protected] (Irdeto2) card V2
    I use from Newcamd v6.05 cardserver.i386 put in /newcam directory and cardserv.cfg in /etc/newcamd which is like this:
    DESKEY = 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    SERVER_NAME = cardserv
    DEBUG_PORT = 1400
    ADMIN_PORT = 1401
    ENTITLEMENT_PORT = 1402
    ADMIN_PASSWORD = secret 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    USER = user1 pass1 lan
    USER = user2 pass2 lan au
    DEBUG_INIT = no
    DEBUG_NET = no
    DEBUG_ECM = no
    DEBUG_EMM = no
    SERIAL_PORT = 0
    PARITY = off
    TCP_PORT = 21000
    CARD_DETECT_BIT = CTS
    EMM-G = yes
    EMM-S = yes
    EMM-U = yes
    SPECIAL_FEATURES = no
    Also tried to change the values for EMM-G,S,U and card detect bit
    The result of all those,are that i can see normaly for about one day and then screen goes black and wincsc gives a message like this:
    Wrong ****** CHID = 0013 PROV =00 KEY =00
    Wrong ****** CHID = 0014 PROV =00 KEY =00
    Wrong ****** CHID = 0015 PROV =00 KEY =00
    >> Searching next valid server (Reason:Keys Missing)
    Then i have to put my card to a sat decoder to unlock and be able to watch again through card server..
    So far i assume that my problem is that wincsc plugin which i use to connect to the card server,with progdvb,doesn't send EMMs data to update the card,but i don't know if i am right..Is there any way to fix this?Or can i use any other plugin to do the same job?The send EMMs option in wincsc is shadowed and can't be enabled.
    Noone has ever setup something like this..?
    Haven't anyone met this problem before..?
    karachi
    sharing server p4 computer dsl server and roter
    love
    If it can't work on a lan,it surely won't work either on wan..
    Anyone here having setup newcamd with irdeto2 card could post his cardserv.cfg configuration so i could see where i am wrong?
  1. WinCSC :: Newcamd & Radegast CS plugin (ex. WinNCD)
    By Anonymous in forum Placi DVB
    Last Post: 8th January 2007, 15:47
  2. WINCSC
    By bila34 in forum Placi DVB
    Last Post: 22nd October 2006, 18:06
  3. WinCSC P*lsat Ok !
    By Alex968 in forum Placi DVB
    Last Post: 29th September 2006, 22:26
  4. Offline WinCSC?
    By RadioactiveNoise in forum Placi DVB
    Last Post: 23rd February 2006, 16:39
  5. sharing - wincsc ?
    By xjust in forum Placi DVB
    Last Post: 6th June 2005, 13:47
