    Jun 2006
    popescu bogdan PE FACEBOOK
    Default ecm mare sau problema cutie de vise blocata
    Nu gasesc unde s-a mai discutat, sorry
    In vara am mai curatat cccam cfg si o vreme nu am mai patit asta
    Plec la ora 7 la servici dupa un restart la dreambox apoi la 14.000 cand vin
    mai nou il gasesc blocat chiar daca am script de restart functional verificat si apasand pe telecomanda nici nu mai pot intra in nimic trebuie sa scot cutia de vise din priza atat arata de SUPT (scuzati expresia) am doar 18 linii!
    pun aici bineinteles numele user schimbat ce am gasit ultima data in cccam info la CCcam 2.2.1 server
    Username | Host | Connected | Idle time | ECM | EMM | Version| Last used share |
    |XXXXXXXX |xxxxxxxxxxxxxx|00d 02:52:11|00d 00:00:19|652 (595) |0 (0)|2.1.3 |0b02:000000:2b0f (nok) |
    |XXXXXX11 |xxxxxxxxxxxxxx|00d 01:59:47|00d 00:00:02|667 (654) |0 (0)|2.0.11 |0b02:000000:78be (ok) |
    |xxxxxx2222 |xxxxxxxxxxxxx |00d 00:12:47|00d 00:00:01|9729 (6759)|0 (0)|2.1.2 |Sky Germany [NDS 09C4] (ok)|
    Ca ideea vad ca unu logat de 12 min are 9729 valoare ecm?
    apoi
    Connected clients: 19
    4 ACTIVE CLIENTS IN LAST 20 SECONDS
    |xxxxxxxx6 |xxxxxxxxxxxxxx |00d 03:27:22|00d 00:00:02|546 (1 |0 (0)|2.0.11 |0b02:000000:042c (nok) |
    |xxxxxxxx5 |XXXXXXXXXXXXX |00d 03:03:30|00d 00:00:04|682 (597) |0 (0)|2.1.3 |0b02:000000:042c (nok) |
    |xxxxxxxx4 |XXXXXXXXXXXXXX|00d 02:11:06|00d 00:00:01|871 (85 |0 (0)|2.0.11 |0b02:000000:78be (ok) |
    |xxxxxxx33 |XXXXXXXXXXXXXX |00d 00:09:16|00d 00:00:00|10455 (7174)|0 (0)|2.1.2 |DIGI TV - RTL Televijia [N3 1802] (nok)|
    sau ce puteti sa imi recomandati sa mai fac?
    sper sa nu deranjez pe nimeni unde am postat
    Multumesc
    Apr 2008
    Din pacate nu se mai actualizeaza nici o versine de CCcam care a pierdut enorm de mult teren in fata tanarului oscam, deci solutia ta ar fii trecerea la oscam care reduce enorm traficu si te limitaza la cea ce vrei tu sa vezi, deci treci pe oscam.
    Apr 2008
    Salut,
    Daca ai peers care au Multics, Csp sau Oscam prost configurat..cam asa arata..
    Raportat la batranul cccam...pune aici un config pt 20-25 locale(sau hop 1)
    Cccam este ok..
    Apr 2008
    Din pacate batrani mor.
    Wild West
    Quote Originally Posted by goguu View Post
    Nu du lumea in eroare ...
    " Tanarul oscam " este de fapt " batranul mpcs " intinerit, aparut cu mult inaintea cccam, asa ca ... tinerii bastarzi gen cccam mor mult mai repede ...
