    Default Saeed bhai...plz help
    As per ur advice I edited keys 01,11-03,13 and 08,18 under provider id 007C00 . I put the new AES keys found in this forum for my starsat x150d+. Now my multivision is working fine. and I found out that keys 01,11 are the right keys to edit and supported by my receiver. Now my spice platinum is not working which was working fine before changing the keys. Maybe I have to change back the keys for 03,13 and 08,18. But I dont have the earlier values. plz advice how can I have spice platinum working again. Thanks
    Nov 2003
    United Arab Emirates
    friend i think go to factory default setting and after that input keys 01 and 11 hope your problem will solve :P
    Quote Originally Posted by dodi
    Spice Platinum resides on key 08: AFAA50ACBBD8263B
    thanks for the reply guys. Luckily I was able to solve it immediately I posted the question earlier. Actually I re-entered the keys for 08 and deleted 18 which made spice work just fine. The point to be noted is that when I re-entered the correct keys for 08 and did not deleted the 18 entry, spice didn't worked. To make spice work I had to re-enter the 08 keys and delete the 18 entry completely. Hope it helps other friends also.
    Thanks
    May 2004
    yes for starsat receivers multivision works on 01 & 11 splitted AES keys and spice works on 08 index of keys on the same provider.
  1. faysal bhai plz
    By kashif in forum RDI - English
    Last Post: 27th June 2006, 01:53
  2. Masod , saeed . bokony ph please need help
    By weso in forum RDI - English
    Last Post: 25th May 2006, 02:47
  3. Farrukh bhai
    By nazirahmed in forum RDI - English
    Last Post: 21st August 2005, 08:34
