Results 1 to 14 of 14
    Default HUMAX 5400 PROBLEM
    pls after powering my hummy it cannot go beyoung the loader 2.07,when it get there it will just stop and continue to show 2.07 on the front pannel of the reciever,i mean it cant get to the next stage which is VIEWING THE CHANNELS ,pls guide me
    ssss
    i have use the link you posted to me but still did not solve the problem,after patching it i power on the humax but still( H2.07)on the front pannel
    help me out pls
    ssss
    Nov 2003
    Bootloader 2.07? not 2.08!
    1m Toroidal (Astra;Hotbird;Sirius;Thor)
    DM500 DM800 Vu+duo
    You must make a flash erase:
    Run HDFSmart and select in menu: Config ---> Data Dictionary Select firmreset.rdd. Quit HDFSmart.
    How to use AllFlash_Reset_v12.hdf:
    1 - Turn your IRCI-5400 to standby mode
    2 - Run HDFSmart and load AllFlash_Reset_v12.hdf
    3 - Select all blocks, send them to STB and press "STANDBY" key in IRCI-5400
    4 - Wait for ALL AllFlash_Reset_v12.hdf is uploaded and written to Flash
    (it can take several minutes)
    5 - When "End" is displayed, run HZU20 or HU15 or HDFSmart and load the firmware you like
    6 - Check for correct firmware CRC or for errors or warning from HDFSmart
    7 - Press "Upload (PC->STB)" key and press "STANDBY" key in your IRCI-5400
    8 - When "End" is displayed, press "STANDBY" key in your IRCI-5400 and upload settings channel list with your usual Settings Editor for Humax.
    great thanks kroky,this is the kind of explaination and directions the members here need.
    ssss
    pls were can i get( Allflash _ Reset _ v12.) or is it the same with( Eraser_ Humax 5400)
    ssss
    Lost Ice Cap of Kilimanjaro
    Default Humi 5400 problem
    Problem solved?
    Taro
    Lahore
    Default Re: Humi 5400 problem
    Quote Originally Posted by taro
    Problem solved?
    Taro
    same here
    Fte Max 100S
    Humax IRCI-5400z
    yap,problem solved masood and taro.but not with All_flash reset.Humax cleaner do the job.so spectacular,RDI UNBEATABLE FORUM hahahaaaaaaaaaaaaa
    ssss
    EUROPE
    If HUMAX 5400 not receiving signals fron dish
    and all other options are OK then what is the
    main problem
    When use any other digital receiver with same dish
    then no problems with signals at all
    Lahore
    Quote Originally Posted by Hawk
    main problem
    To solve your problem you will have to spare some time on your STB dear Hawk jee!
    Fte Max 100S
    Humax IRCI-5400z
    Nov 2005
    KSA
    Quote Originally Posted by Kroky
    man u are great, today my Humax5400 started behaving in a similar way, when i clicked the stanby key on remote on 3 dots . . . appeared on front display, it didnt give the "tick" sound to load channels.
    i did what you have mentioned here, loaded the new toh6.5 and now im fine.
    great help, thanks again
    STB info:
    Humax5400 with ****** FREECAM 2-019, Coship, Manhattan Plaza ST550 PVR with 80GB Maxtor Quickview HDD.
    Dish Info:
    HotBird,NileSat;ArabSat;Panamsat-10,AsiaSat3s
    Subscriptions:
    Showtime,Pehla
  1. Humax 5400 problem
    Last Post: 12th May 2006, 00:12
  2. humax 5400 problem
    By jim in forum RDI - English
    Last Post: 29th January 2006, 14:42
  3. humax 5400 problem
    Last Post: 20th January 2006, 15:31
  4. HUMAX 5400 PROBLEM
    By stefen in forum RDI - English
    Last Post: 17th November 2005, 00:44
  5. humax 5400 z problem
    By leventenagy in forum SD Receivers
    Last Post: 12th September 2005, 23:57
