Results 1 to 15 of 29
    Banned Teacher
    Dec 2008
    Default cron job problem
    am pus un job la cron
    *3/ * * * * /etc/cron/example/osc.sh
    la etc/cron.crontab/root---am acesta informatie
    3 ba.sh ba.sh ba.sh ba.sh /etc/cron/examples/osc.sh
    proc/3 ba.sh ba.sh ba.sh ba.sh /etc/cron/examples/osc.sh
    este corecta secventa dupa 3 ? , sa afiseze Ba.sh? sau trebuie sa fie altfel?
    am primit mesaj error cron
    Jun 9 19:40:51 dm800 user.warn kernel: [149767.386000] set wss 8 on display 1
    Jun 9 19:40:51 dm800 user.warn kernel: [149767.386000] set sb to 3(2)
    Jun 9 19:40:51 dm800 user.warn kernel: [149767.471000] pilot_off!
    Jun 9 19:46:54 dm800 user.warn kernel: [150130.803000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jun 9 19:46:54 dm800 user.warn kernel: [150130.912000] set current avs auto aspect to 4:3
    Jun 9 19:46:54 dm800 user.warn kernel: [150130.912000] set wss 8 on display 0
    Jun 9 19:46:54 dm800 user.warn kernel: [150130.913000] set wss 8 on display 1
    Jun 9 19:46:54 dm800 user.warn kernel: [150130.913000] set sb to 3(2)
    Jun 9 19:46:56 dm800 user.info kernel: [150132.356000] RCU: dropping invalid key code 4a0f441a
    Jun 9 19:46:58 dm800 user.err kernel: [150134.455000] 150434:455700000 SMCA: invalid ioctl: 0x00005407
    Jun 9 19:59:01 dm800 cron.err crond[829]: user root: parse error at ba.sh
    Jun 9 19:59:01 dm800 cron.err crond[829]: user root: parse error at proc/3
    Jun 9 20:59:01 dm800 cron.err crond[829]: user root: parse error at ba.sh
    Jun 9 20:59:01 dm800 cron.err crond[829]: user root: parse error at proc/3
    Jun 9 21:25:21 dm800 user.warn kernel: [156037.877000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jun 9 21:25:21 dm800 user.warn kernel: [156037.994000] set current avs auto aspect to 4:3
    Jun 9 21:25:21 dm800 user.warn kernel: [156037.994000] set wss 8 on display 0
    Jun 9 21:25:21 dm800 user.warn kernel: [156037.995000] set wss 8 on display 1
    Jun 9 21:25:21 dm800 user.warn kernel: [156037.995000] set sb to 3(2)
    Jun 9 21:25:35 dm800 user.warn kernel: [156051.717000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jun 9 21:25:35 dm800 user.warn kernel: [156051.834000] set current avs auto aspect to 4:3
    Jun 9 21:25:35 dm800 user.warn kernel: [156051.835000] set wss 8 on display 0
    Jun 9 21:25:35 dm800 user.warn kernel: [156051.835000] set wss 8 on display 1
    Jun 9 21:25:35 dm800 user.warn kernel: [156051.835000] set sb to 3(2)
    Jun 9 21:28:02 dm800 user.warn kernel: [156198.180000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jun 9 21:28:02 dm800 user.warn kernel: [156198.297000] set current avs auto aspect to 4:3
    Jun 9 21:28:02 dm800 user.warn kernel: [156198.297000] set wss 8 on display 0
    Jun 9 21:28:02 dm800 user.warn kernel: [156198.297000] set wss 8 on display 1
    Jun 9 21:28:02 dm800 user.warn kernel: [156198.298000] set sb to 3(2)
    Jun 9 21:33:47 dm800 user.warn kernel: [156543.711000] VIDEO0: dst_left, dst_top, dst_width and dst_height is 0.. reset to defaults!
    Jun 9 21:33:47 dm800 user.warn kernel: [156543.823000] set current avs auto aspect to 4:3
    Jun 9 21:33:47 dm800 user.warn kernel: [156543.823000] set wss 8 on display 0
    Jun 9 21:33:47 dm800 user.warn kernel: [156543.823000] set wss 8 on display 1
    Jun 9 21:33:47 dm800 user.warn kernel: [156543.823000] set sb to 3(2)
    Jun 9 21:33:50 dm800 user.warn kernel: [156546.255000] set mute 1 (111) 0
    Jun 9 21:33:50 dm800 user.warn kernel: [156546.295000] set input to 1
    Jun 9 21:33:50 dm800 user.warn kernel: [156546.295000] set fb to 2(0)
    Jun 9 21:33:50 dm800 user.warn kernel: [156546.303000] set sb to 3(0)
    Jun 9 21:33:56 dm800 user.warn kernel: [156552.327000] alps_bsbe2 is in powersave mode now
    Jun 9 21:38:31 dm800 user.info kernel: [156827.925000] RCU: dropping invalid key code 0e1e441a
    Jun 9 21:38:45 dm800 user.info kernel: [156841.286000] RCU: dropping invalid key code 02702500
    Jun 9 21:59:01 dm800 cron.err crond[829]: user root: parse error at ba.sh
    Jun 9 21:59:01 dm800 cron.err crond[829]: user root: parse error at proc/3
    cum pot repara sa ruleze, corect cron--- scriptul meu
    unde este greseala?
    multumesc
    Banned Teacher
    Dec 2008
    cum verific, daca cron ruleaza? ( este activ)
    unde ma uit? sa-l vad ...
    pentru istoric, verific , la log>message.
    multumesc
    efectiv nu stiu ce sa-i mai fac sa mearga.
    In The Matrix Expert
    near Arad
    nu asa trebuia sa pui cumva ?
    */3 * * * * /etc/cron/example/osc.sh
    Sep 2010
    corect ce a spus raks67, ai gresit sintaxa.. probabil ca vrei sa iti ruleze scriptul la fiecare 3 minute.. deci urmeaza exemplu lui.
    cron ar trebui sa iti functioneze automat, ca sa verific dai si tu "ps ax|grep cron" ar trebui sa iti apara 2 pid-uri in lista, unu este grepul si altul este cron (/usr/sbin/cron.. sau ceva de genul). daca e acolo, inseamna ca ruleaza.
    Banned Teacher
    Dec 2008
    asa am editat si eu -- dar nu a luat root bun.
    sa dau un update la cron?
    la mine este o versiune pentru 7025,....si are sytaxme diferite, la editare crontab, vizualizate la exemple.
    ii dau un update sa vedem ce descarca.
    si acum am citit help
    si spune ca se evidentiaza run - la sbin
    Banned Teacher
    Dec 2008
    deci am dat update la 11:30 ( script lor de update este iup.sh-- oferit la exemple }
    apare
    Execution process;
    new crontab time will be like this:
    30 11 * * * /etc/cron/example/iup.sh
    crontab can't open "root" : No such file or directory
    dislaying new crontab :
    30 11 * * * /etc/cron /example/iup.sh
    execution finish !
    deci trebuie sa-i creez un director Root in Crontab
    asta inteleg eu
    si culmea
    am verificat etc/cron/crontab
    si are
    doua fisiere
    root................. atribut 600 si contine
    30 11 * * * /etc/cron/examples/iup.sh
    si
    cron ....... Extensie update , no atribut
    si contine
    root
    root
    Banned Teacher
    Dec 2008
    am creat new director "root" dar nu l-a acceptat
    pentru rulare la 3 minute a luat ( fiind ver veche ]
    syntax
    etc/cron/exemple/osc.sh 03
    si l-a evidentiat la lista crontab
    sunt curios daca il si ruleaza. evidentiat la log>mesage
    Banned Teacher
    Dec 2008
    a salvat tab
    dar nu le ruleaza
    ce alta varianta am sa execut un script , periodic?
    alt plugin?
    sau un ipk pentru cron. sa mearga pe DM , nemesis.
    ceva testat, care funtioneaza
    asta este ver 2.2- by gutemine pentru 7025
    multumesc
    near Arad
    varianta cea mai buna e cu cron , dar posibil ca problema sa fie de la imagine , si eu am avut probleme cu cron pe unele imagini , nu mai stiu exact care dar au fost vreo 2 - 3 , am instalat gemini E1 pe dm500 E2 pe DM800 si merge perfect cron , numai sa ai scriptul potrivit kkkamcheck.sh
    Jul 2007
    Default Cron
    Eu folosesc img NEMESIS 2.6{ svn 107r5 } E2 DM800SE in care e instalat si pluginul 2.2 si imi functioneaza perfect pe CCcam.
    Probabil multi stiu sa o foloseasca deja dar fac un mic tutorial ptr imaginea Nemesis:
    Aveti aici 2 fisiere pe care trebuie sa o instalati manual cu calea:
    Root-ul in var/etc/cron/crontabs si punem atribut 755
    EMUSTARTER.SH in var/ script tot atribut 755
    http://www.hotfiles.ro/download/cron...sis.rar/903871 AICI SUNT CELE 2 FISIERE
    Intram in : MENU/PLUGIN/CRONMANAGER/LIST CRONTAB, SI TREBUIE SA VA APARA ASA:
    */1 * * * * /bin/sh /var/script/emustarter.sh start /dev/null EU AM PUS PE 1 MINUT
    Executam o comanda din telnet: crontab -e .
    Dupa apasam butonul ALBASTRU urmat de ROSU START/STOP SERVICES si aici activam
    Contab sa ruleze. Urmat sa apasati butonul verde si
    ACTIVATE CRONTAB AT BOOT? si o punem pe YES urmat de un reboot si totul functioneaza perfect.
    Si daca functioneaza dam comanda din telnet PS si vedem daca ruleaza..
    Am uitat sa specific modificati in emustarter.sh versiunea de CCCcam pe care ofolositi...
    Bafta... Testat functional 100%
    In rest numai bine...
    [IMG] Uploaded with ImageShack.us[/IMG]
    Banned Teacher
    Dec 2008
    Default probleme again
    nu reusesc sa gasesc link-ul de download -- pe hotfiles.ro, la link-ul specificat.
    trebuie platit, la acest site, pentru download
    poti sa-l ridici si pe 4share.com si sa setezi contul ca public share,...
    multumesc
    PS:am reusit intr-un final, accesand link de servere hotfile.ro ,fileshare.ro ,girlshare.ro, din lista ,.......ok
    am sa-l testez,...pe un script de restart Oscam
    Banned Teacher
    Dec 2008
    nu exista
    Banned Teacher
    Dec 2008
    am pus in usr{var}/script/emustarter.sh-- atribuit 755
    si l-am rulat cu
    TS pannel7.1>tools2>script manager
    a confirmat ca ruleaza ok
    idem am facut corecturi la scriptul de Oscam_Check....l-am rulat, si am primit confirmare de OK
    mai trebuie doar sa reusesc sa pornesc cronmamager asta odata. sa ruleze el scriptul.
    oricum m-a ajutat emustarter.sh - sa corectez scriptul meu, {avea 2 greseli in el, pe care nu le-as fi depistat niciodata}.
    de cand am instalat acest Ipk , mi-a disparut mie Cronmanager > de la plugins> de la Meniu [ si am reinstalat un back-up imagine- dar nu a revenit la forma initiala la plugins, CRON -- acum nu mai este acolo defel ]
    enigma2-plugin-extensions-cronmanager_0.2.2-r3_all.ipk
    http://www.rdi-board.com/threads/143...um-se-porneste
    eu am DM 800 simplu cu imaginea nemesis2.3 ver095r de rahmi
    daca pornesc TS pannel >Tools-2>crons Manager> apare ecran verde- ERROARE, restart
    intr-un final am primit confirmarea ca ruleaza Cron
    825 root 2788s /bin/sbin/crond -c /etc/cron/crontabs
    multumesc lui gilboa
    EXPERT GIGABLUE & IPTV Expert
    Feb 2010
    mai stiti care e culmea....?
    eu de cand sant prin acest hobby si e cevaaaaa vreme,nu am folosit niciodata script ptr emulatoare,fie ca e 3C sau oscam
    care e problema?
    receptoru?
    imaginea?
    emulatoru?
    sau toate la un loc?
    nu as vrea sa detaliez mai multe
    GIGABLUE 800HD SE...GIGABLUE
    Banned Teacher
    Dec 2008
    Quote Originally Posted by iooon View Post
    care e problema?
    receptoru?
    imaginea?
    emulatoru?
    chiar nu vreau sa intru la amanunte, care pot sa ma depaseasca, atat pe mine cat si pe tine,...
    ideea de baza , este ca vreau sa folosesc un anume EMU, care imi face probleme dupa 4-5 ore de functionare.
    acest EMU il am atat pe DM 8000 cat si pe DM 800 ( in ambele parti face figuri dupa 4 ore }
    Imaginile pe boxuri sunt diferite- deci nu este imaginea de vina.
    Boxurile sunt super ok
    problema este cu acest EMU, si trebuie sa rezolv resetarea lui....
    solutia practica este job la un plugin ( cronos) sa restarteze EMU respectiv, in urma unor fedbackinfo din EMU oscamCheck(file).
    si tot nu lucreaza Cron manager, scriptul.
    scriptul este corect, verificat, ruleaza corect.(l-am tot modificat, pana a puscat corect)
    daca il execut manual- primesc confirmare ca este executat corect , si afiseaza in folder .Check-- status OK.
    dar aceasta informatie ar trebuie sa apara la fiecare minut, dupa executare de catre Cron manager din root-- dar asta nu se intampla, din pacate.
    deci problema mea actuala este ca nu reusesc sa pornesc JOB la cronos,...! sa execute ce vreau eu.si nu stiu unde este problema ,...
    deci poate imi recomanda cineva o arhiva sau Ipk , pentru Ver 2.2 sau mai mare a lui gutemine, sau alt autor
    am mai gasit o versiune 1.7 de Thowi
    Cronmanager for Dreambox 7025 1.7 by thowi from 2. January 2007
    sunt dispus sa incerc si alt plugin - care poate executa un script-- multumesc
    acest cron - de pe imaginea mea actuala spune ca ruleaza - dar nu se vede real nimica.
    si Cronmanager a disparut total de la Meniu>plugin>
