Results 1 to 2 of 2
    Jun 2006
    Default Probleme cu gp3 wizard
    Salut
    Am pus gp3 wizard 0.16 si nu merge. Dupa instal si reboot nu apare blue pannel. E prima data cand patesc asta...indiferent ce imagine pun. Folosesc imaginea E02.0 Experimental(CVS gemini)
    Numai bine
    Wink
    Quote Originally Posted by ded_cky View Post
    Salut
    Numai bine
    Exista modificari:
    Code:
    enigma2 20130503b (master) -> 20130607 (master)
    - better debug support for eTimer/eSocketNotifiers used from wrong thread
    - UPnPMediaRenderer: fixed state handling (stop was never emitted)
    - HbbTV: always use .mp4 as file extension for downloaded movies
    - MiniDLNASetup: fix broken share handling
    - fixed a segfault on fast service change (services with subservices)
    - fixed a listbox skin bug (dont use lef/right config offsets for decoration (selection pixmaps)
    - fixed comment about config_item_height in skin_default.xml
    - added missing import of eListboxPythonConfigContent (fixes config_description and config_value font)
    - fixed infrequent crashes on enigma2 restart
    Code:
    usr/include/enigma2/lib/base/ebase.h
    usr/include/enigma2/lib/python/python.h
    usr/lib/enigma2/python/Plugins/Extensions/HbbTV/HbbTV.py
    usr/lib/enigma2/python/Plugins/SystemPlugins/MiniDLNASetup/plugin.py
    usr/lib/enigma2/python/Plugins/SystemPlugins/UPnP/UPnPMediaRenderer.py
    usr/lib/enigma2/python/mytest.py
    usr/lib/enigma2/python/skin.py
    usr/share/enigma2/Default-HD/skin.xml
    usr/share/enigma2/skin_default.xml
    Mai multe aici: http://git.opendreambox.org/?p=enigm...7bb58a9ea53cb1
    Intradevar, cu tool OneStep Cam Feed Installer 0.0.5.2, nu am reusit sa instalez Gemini3 Wizard si Gemini Plugin si nici softcam-urile, dar...
    ...pe DM800HDse, azi am pus in Flash, dreambox-image-dm800se-20130608.nfi
    Cu MeoBoot am pus pe stick USB(fara probleme): dreambox-image-dm800se-20130608.nfi
    Cu DCC E2 v1.50 am instalat Gemini3 Wizard(g3wizard_0.16-r0_all.ipk).
    Dupa restart GUI, din plugin Gemini3 Wizard am instalat Gemini Plugin, iar apoi cu tool OneStep Cam Feed Installer 0.0.5.2 am reusit sa pun softcam-urile..
