    Default need help for xsat cdtv410 stb?
    does xsat cdtv410 stb dream au?
    have you tried it with funcard4 or atmega8 with au files on it?
    in the best story
    Default Re: need help for xsat cdtv410 stb?
    Quote Originally Posted by jufighter
    Your X-sat model is cdtv410 stb but I think that which is clone of NS-3000.
    Some X-sat stb are the same NS-3000 . But body design is different.
    You should try download the software of NS-3000.
    Regard
    walking is better than sitting
    Running is better than walking
    hmmm interesting. i was thinking the xsat has a clone under the name of BOLT, and the softwares are different, does the au via funcards.
    @jufighter,
    better get a funcard4 with autoroll, to be safe. im not sure if that is indeed a clone of ns3000/victory as these boxes uses a fujitsu chipset (im not sure which chipset is used on your 410). most xsat boxes do not have a code menu on them and needs a card to view the channels, otherwise they are plain FTA receivers. just a warning to be carefull. better to be safe than sorry.
    Senior Member Teacher
    May 2005
    On The Move
    @jufighter
    yes...xsat cdtv410 works fine with atmega 8 card for dream auto.
    Regards
    ART IS TO COMMUNICATE.....
  1. Xsat cdtv410
    By matei26bogdan in forum SD Receivers
    Last Post: 19th December 2006, 20:25
  2. How to ad key in to Xsat 410 ??? HELP
    By mlccs in forum RDI - English
    Last Post: 3rd February 2006, 17:00
  3. CDTV410 software upgrade
    By victorlai in forum RDI - English
    Last Post: 25th October 2005, 17:37
